Help. I have a 70 Coupe that I am hoping to put AR Torque Thrust D's on.
I heard that 15" wheels will be a problem because of the calipers. Do I have options other than 16" or 17" wheels? If not, does anyone have size info?
The II look great on your car. What size tires are you running and what is the stats on your wheels? Backset, ect. ect.? I'm new to this game, how do I get ahold of yellow 72? Tim
Wheels are 15 x 8 with 4 inch backspacing. Front tires are 255/60 15s and the rear tires are 275/60 15s. I also have offset trailing arms so I'm not concerned about the tire hitting the parking brake bracket.
Here is a picture of Yellow 72's car.
If you want to ask him a question, go to this forum post and under his profile you will see the letters "IM", click on that and you then can send him a message through the forum. Rod http://forums.corvetteforum.com/zerothread?id=296618
