headlight/vac issues
Old May 24, 2012 | 04:00 PM
haydengm1's Avatar
haydengm1
Default headlight/vac issues
I am sure this has been asked before but I can't find the answer to my questions. I have a 1975 with a 468 in it that has a vac pump installed and now I am working through some vacuum issues. My main problem is the headlights, both sides, came up when I started the vac pump and now won't go down. What is causing them to stay up ? Could the headlight switch vac lines be reversed ? Bad override switch ? Or do I have a line hooked up incorrectly ? How can I make the headlight doors close ? Thanks in advance for your help.
Old May 24, 2012 | 04:04 PM
...Roger...'s Avatar
...Roger...
The relay needs vacuum on the small hose to tell the lights to go down. Check for vacuum there.
Old May 26, 2012 | 01:13 PM
haydengm1's Avatar
haydengm1
Thanks Roger that helped
Old May 26, 2012 | 01:22 PM
scottyp99's Avatar
scottyp99
Here's some great info on how our headlight vacuum system works, and how to troubleshoot it.
http://forums.corvetteforum.com/c3-t...tem-works.html
Keep the shiny side up!
Scott
Old May 29, 2012 | 02:06 PM
haydengm1's Avatar
haydengm1
Thanks Scott
Great information
Old May 29, 2012 | 10:24 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Just a lil ole tip I learned with hose order and an older memory.
Looking at either relay from above order is same as a traffic light.
Red, Yellow, Green top to bottom. I figured that one out all on my own
Marshal
To headlight/vac issues
