OE vs aftermarket
Old May 24, 2012 | 10:52 PM
dburgjohn's Avatar
dburgjohn
Default OE vs aftermarket
two years ago I bought a store brand master cylinder and booster from a chain store. When trying to bleed the brakes I discovered I had to put a washer between the MC and booster because the pin would not let the MC piston come all the way back.
Fast forward to present day. The rear seal failed, booster drew brake fluid in and failed. This time I ordered AC Delco online since all chain stores no longer carry it.
Bottom line is firm and brakes are better than ever and I love it! Any one else notice this?
Old May 24, 2012 | 11:23 PM
oldalaskaman's Avatar
oldalaskaman
is it possible you should have took it back and got the right part...two years ago?
Old May 25, 2012 | 12:20 AM
tfi racing's Avatar
tfi racing
Isn't AC Delco the same Chinese or Mexican parts in just a different package?
Old May 25, 2012 | 12:48 AM
briankeery's Avatar
briankeery
Probably........but more expensive, so it must be better!!!!
Old May 25, 2012 | 09:41 AM
dburgjohn's Avatar
dburgjohn
Default 2 years ago
two years ago I figured that was all there was to use. Why would I put all the labor in to swapping it out for just the same thing? This time when I went looking, I only knew one of the brands available and had trouble with it in the past.
The Delco part was not more expensive than the other new parts available locally, I just had to wait a few days for it to arrive. I'm not even going as far as saying Delco is better. In fact the original post wondered if any body else had experiences like mine.
I guess it is a sign of the times that replacement parts all need 'fitting' to work like they should.
Old May 25, 2012 | 10:17 AM
Solid LT1's Avatar
Solid LT1
AC will be Chinese made too. I think Stainless Steel Brakes has some of the last USA made brake product.
To OE vs aftermarket
