Starting my engine
Old May 23, 2002 | 08:15 AM
bbeck's Avatar
bbeck
Default Starting my engine
Last night, after I got home from my graduation, my car rolled over and fired numerous times, but won't stay running. I had the same problem before, and ended up it was the selenoid. The starter is new last fall- used very little. Think the selenoid went out again? or something else?? wiring problem?? Just looking for ideas before I get under it today.
Old May 23, 2002 | 08:21 AM
78pace's Avatar
78pace
Default Re: Starting my engine (bbeck)
you can check to see it the carb is getting gas and distributor is getting spark
how are the plugs?
Old May 23, 2002 | 08:25 AM
bbeck's Avatar
bbeck
Default Re: Starting my engine (78pace)
It fires up fine, but won't stay running- lacking power somewhere. When I keep the key forward- cranking- stays running. When I let it back to run position- it dies.
Old May 23, 2002 | 09:39 AM
Lasse's Avatar
Lasse
Check if the carb is getting gas :yesnod:
Old May 23, 2002 | 09:41 AM
Fevre's Avatar
Fevre
Did you re intall the starter just before this happened? I put in a new starter once and wired it wrong so it would only run when I engaged the ignition. Rewired it right and it ran fine.
To Starting my engine
