Brake Light Wiring
Old May 27, 2012 | 08:19 PM
RedBill's Avatar
RedBill
3rd Gear
Default Brake Light Wiring
I searched around, and didn't see this on any of the forums. I'm working on hooking up brake lights - and I really don't know anything about corvettes , I kind of inherited the project for a friend. I was given the pigtail connector and the bulb with an empty socket for the light. All of the lights work on the car (license plate, side lights, headlights, etc). For driver's side, I hooked up brown to brown, yellow to yellow. For passenger I did brown to brown, and yellow to green (which looks right according to the wiring diagram). However I get nothing. Not sure if I am doing this right - anyone have advice? There is also a green and black wire hanging down on the driver side. I have some pics here:
http://www.flickr.com/photos/gerriwi...in/photostream
Thanks!!!
Old May 28, 2012 | 02:47 AM
rainmaninwa's Avatar
rainmaninwa
Hey RedBill:
I think you might be missing a ground pigtail to the mounting stud on each tail light can. From looking at your pics, it looks like a recent replacement of the rear body panel with a hand laid up panel has been done. The tail light cans seem to be new and shiny and the mounting washers and nuts are also shiny. However I cannot see any ground wire(s) returning to the frame. I suspect that it (they) may have been left off after the repair.
On my 68 there is a simple pigtail wire that connects all 4 tail light cans to ground. I believe that a similar wire is missing on your vette. I attached a couple of pics of the underneath of my 68 to show you what it looks like as best as I could. It may also be a separate pigtail for each sides 2 lite cans, but I cant tell fully from the pics (I think that woul make the most sense). The pigtail(s) ground the cans to the frame and provide the return circuit for the tail light current. The Corvette fiberglass body panels don't conduct electricity, so a ground return to the frame of some kind is necessary.
Hope this helps.
P.S. Dont get the electrical wires confused with the fiber optic "wires" which are black...
Old May 28, 2012 | 10:03 AM
RedBill's Avatar
RedBill
3rd Gear
I bet that's it! I'll give that a try and post if that is the solution - thanks!!!
Old May 28, 2012 | 10:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by RedBill
...anyone have advice?...
The assembly instruction manual (AIM) shows the factory installation of the rear harness, lamp grounds, and the frame ground for the harness. Some of the AIMs have wiring diagrams in them.
Old May 28, 2012 | 10:47 AM
RedBill's Avatar
RedBill
3rd Gear
I have the AIM, but I don't remember seeing something for a ground wire. I'm sure it was operator error on my part
I had a hard time deciphering that thing. All I got from the previous person was a milk carton full of parts and the AIM, so I have no clue what he has/hasn't worked on. I think I'm in for a reeally long summer
Also, where in the world can I buy that wire?? I checked a bunch of sites, and they all have the pigtail connector that I already have, but not the wire?
Thanks!!
To Brake Light Wiring
