73 Vapor Canister
Old May 27, 2012 | 11:16 PM
mikecamp's Avatar
mikecamp
St. Jude Donor '12
Default 73 Vapor Canister
I am restoring a 73. When I bought the car it was minus the motor and a few other items one being the fuel vapor canister. I have built a stock motor with the exception of headers, intake, hei distributer and holly carb. Now for my question. Do I need the fuel vapor canister?
Old May 27, 2012 | 11:24 PM
1986coupe's Avatar
1986coupe
From what I can see the vapor canister was first added in 1974.
I could be wrong though so please dig a little deeper.
Old May 28, 2012 | 08:36 AM
mikecamp's Avatar
mikecamp
St. Jude Donor '12
ttt
Old May 28, 2012 | 08:42 AM
mikecamp's Avatar
mikecamp
St. Jude Donor '12
My asm shows one with one line going to the pcv valve then to the carb and the second line going straight to the carb.
Old May 28, 2012 | 09:03 AM
Hodge's Avatar
Hodge
my 73 has a vapor canister that was disconnected YEARS ago. It hooks up just like the assembly manual says. I intend to use it when I put the LS1 in.
Old May 28, 2012 | 09:14 AM
oldsarge's Avatar
oldsarge
You are mistaken, the canister was used in 73. It can be run without, but probably a good idea to use one.
Old May 28, 2012 | 11:28 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
It's behind the driver's side wheel well. There are three air/vapour hoses going to it. One is from the PCV line; one is from the carb and one is from the hard line to the tank. You should see the hard line from the tank on the frame rail near the motor on the driver's side. Have a look from underneath. The vapour canister may stilll be hiding under there.
Old May 28, 2012 | 11:32 AM
Mike Ward's Avatar
Mike Ward
It also serves as the vent for the fuel tank to allow air in as the fuel is consumed. Although the system does only good and no evil, Bubba is frequently afraid of it and banishes it from his car.
To 73 Vapor Canister
