Compressor brackets
Old May 30, 2012 | 09:28 PM
justin_heat05's Avatar
justin_heat05
Default Compressor brackets
79 coupe
I am missing some brackets to mount my short a/c compressor. I have the lower bracket but I need to know what other brackets I need to mount it. These were all missing when I got the car 7 years ago.
Pictures would be great.
Old May 30, 2012 | 09:35 PM
markids77's Avatar
markids77
An Assembly Instruction Manual (AIM) will show not only the brackets you require, but tell you where to bolt them as well. It possibly should have been the first "part" purchased after you bought the car... it definitely should be the next. Any major vendor at the left of this page can supply one. My 77 set up is probably different or I'd be happy to supply pics for this issue.
Old May 30, 2012 | 09:40 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
See if these are still available.....
http://forums.corvetteforum.com/c3-p...and-bolts.html
Great price.
Old May 30, 2012 | 09:57 PM
justin_heat05
so there are four brackets total??
Old May 30, 2012 | 10:05 PM
KapsSA's Avatar
KapsSA
Yes.
That big cast bracket is the main mount under the compressor.
The flat one is the adjustment bracket that goes behind the compressor.
The two others are support struts. One goes from an intake manifold bolt to the top of the adjustment bracket, the other goes from near the fuel pump to the bottom of the main mount bracket.
edit.....good pics here....
http://forums.corvetteforum.com/c3-t...-mounting.html
Old May 31, 2012 | 08:07 PM
justin_heat05
Thanks, much apprecited
Old Jun 1, 2012 | 02:03 PM
Rotonda's Avatar
Rotonda
If you are trying to restore your car, you will need these brackets to install an R4 compressor. If you are trying to get your AC to operate again, consider replacing the compressor with a Sanden 508. The 508 draws less power and is FAR more reliable. Alan Grove, Vintage air and others have the necessary mounting brackets. Do a search of the Forum.
Old Jun 1, 2012 | 09:23 PM
scag52's Avatar
scag52
Default Need one ac bracket (have picture)
Hi ,, Anybody have this ac bracket ? I need the one on the far left of the picture? I have the other ones . Thanks for the help. 81 vette C3 auto
Russ 443-907-7455
To Compressor brackets
