voltage jumping around
Old Jun 2, 2012 | 10:17 AM
Larrys69's Avatar
Larrys69
8th Gear
Default voltage jumping around
my voltage is jumping around from 2 to 13 volts.Had alternator checked its good.The car is a 69 should it have an external voltage regulator or internal regulator and would it make a difference.Checked ground wire good and tight.Battery only drains when running.Any suggestions would be very much appreciated.
Old Jun 3, 2012 | 08:58 AM
KenSny's Avatar
KenSny
Without knowing the model number of the alternator we cannot tell if it has an internal regulator or not. If it is the stock alternator (still would like either a pic or a #) then I believe the regulator is external.
Alternator checked by a mechanic? Then he should know the regulator answer, and if external he should have checked that also.
Old Jun 3, 2012 | 10:23 AM
69 Chevy's Avatar
69 Chevy
'69 was the first model year to have the internal regulator.
Old Jun 3, 2012 | 10:39 AM
KenSny's Avatar
KenSny
Thanks, I stand corrected, I could not remember when the change took place.
Old Jun 4, 2012 | 01:30 PM
Larrys69's Avatar
Larrys69
8th Gear
thanks for the help!
Old Jun 4, 2012 | 01:39 PM
Mike Ward's Avatar
Mike Ward
'69s don't have voltage gauges so how have you determined this?
Old Jun 4, 2012 | 01:53 PM
Larrys69's Avatar
Larrys69
8th Gear
placed volt meter on alternator and battery with car off and it holds a steady 12.70 volts.I start the car and perform the same test and the voltage starts jumping around.What caused me to check was the car battery drained when running but holds the charge when not running.Auto parts store said alternator checks good.
Old Jun 4, 2012 | 02:11 PM
Mike Ward's Avatar
Mike Ward
You've got an open circuit, probably on the wire that senses battery voltage and turns the alternator on and off.
To voltage jumping around
