New Alternator Wiring on '79
I'm putting in a ZZ4 crate engine, with serpentine setup, in my '79 vette. The new alternator comes with a different plug than the stock connector. I haven't had any luck finding an electrical diagram. Can anyone here give me some pointers? Below is a link to pics of my stock connector and the connector for the new alternator. Any assistance much appreciated. Almost finished with this project...
https://skydrive.live.com/?cid=f31f7...A4FB475D92!571
Yep,
It's important for that CS130 that you designate if you have gen light or not. If not, then you need to get the adapter that has built in resistance. If you do have a gen light then the incandescent light bulb will provide the resistance you need. I wired my 70 with a custom gen light and I got the adapter by Painless from Summit. Nice little kit. It came with a resistor in the pack to cover both bases. If you don't get this resistance scenario straight, your alternator will go "bye bye" in a couple hundred miles.
Good luck.
Good luck.
L is only live when sw is on....now many sharks did not have a light, just a resistance wire to that alt sense point....it is always from a switched source, never live with ign sw OFF....
