Summit Stainless Flexable Radiator Hose
Old Jun 2, 2012 | 04:25 PM
JP_80's Avatar
JP_80
Default Summit Stainless Flexable Radiator Hose
Has anyone used the Summit Stainless Flexable Radiator hose kit? If so do you just insert the flexable hose into the largest hose adapter and clamp it down? It seems a little to loose. It didn't come with any instructions, there website doesn't have them and tech support is closed on Sat and Sun.
Old Jun 2, 2012 | 07:07 PM
Billysvette's Avatar
Billysvette
You use the adapters until you get the right fit.You have the main piece of hose and then you slide in the spacer pieces until you get the right fit then clamp it down.
