Power window
Old Jun 2, 2012 | 09:26 PM
cars78md's Avatar
cars78md
Cruising
Default Power window
I own a 1978 corvette . pas. side window stop working. it work fine the last time i used it. It make no noise ,justed nothing. How can i tell which one is bad.the motor or the switch?
Old Jun 2, 2012 | 10:07 PM
Bills17n72's Avatar
Bills17n72
well dont know how to tell if it if bad ,but if you need a new motor ,I have one out of a 79 $35
Old Jun 2, 2012 | 10:33 PM
1986coupe's Avatar
1986coupe
Test the switch first. Use your multimeter to see if current flows between the contacts when the switch is used. If not then the switch is done.
Old Jun 3, 2012 | 07:52 AM
...Roger...'s Avatar
...Roger...
Do you see any reaction from the dash voltmeter pushing the switch either way ?
Assuming the window is up,if you see no reaction pushing the switch to down but there is a reaction when pushed to up then its highly possible the down wire is broken in between the door and body.
Old Jun 3, 2012 | 10:01 PM
lvmyvt76's Avatar
lvmyvt76
take the door panel off and use a test meter on the leads to the motor, one is up, one is down, ground on side of the meter to a good ground on the door or frame, should read 12volts when current is applied via the switch, no 12volt, may be in the switch. Need to test for voltage at switch then. No current there, then keep going to the fuse panel via the wiring to see where the problem is. Is the wiring going from the post into the door OK? could be broken there, then power would be at the switch and making it to the motor then. A bad ground could be the problem at the door, no ground no workie.
Old Jun 3, 2012 | 10:02 PM
lvmyvt76's Avatar
lvmyvt76
if 12volts at door and there is a good ground, then motor is bad, or locked up, but that should show at the volt meter on the dash, if it works.
Old Jun 10, 2012 | 06:48 PM
cars78md's Avatar
cars78md
Cruising
Default Power window fixed.
IT WAS THE MOTOR NOT THE SWITCH . COST $350.00 TO HAVE IT FIXED.JUST WHAT TO THANK EVERYBODY FOR THERE HELP......
Old Jun 10, 2012 | 09:27 PM
...Roger...
Ouch
To Power window
