Tappers
Old May 23, 2002 | 07:16 PM
Koz
Guest
Posts: n/a
Default Tappers
On the way home I started hearing a loud tapping noise on engine passenger side.. Sounded like an exhaust leak but now I think it is a rocker.. Engine is too hot to remove cover. Years ago I remeber adjusting the rockers by loosening until they knocked and then tighten until they stop and then 3/4 turn more. Is that a valid way to adjust rockers? Could a rocker all of a sudden start tapping loud or am I in for bigger problems.. Noise got louder under strain.. in gear giving gas. Not as noticable, but still there out of gear reving engine. Any words of wisdom?
Old May 23, 2002 | 07:31 PM
DollaGreen's Avatar
DollaGreen
Default Re: Tappers (Koz)
Sounds like what I am having...Im going to watch this too...
Old May 24, 2002 | 11:38 AM
Koz
Guest
Posts: n/a
Default Re: Tappers (DollaGreen)
I pulled the passenger valve cover off last night.. Put an old shirt over manifold to catch oil spray and started her up.. No tapping noise? I loosend a rocker to ensure I would hear the tapping noise.. which I did. but it was different. I replaced the cover and I hear tapping louder on the passenger side but I think it's comming from the carb? Can't explain it. I decided to check the timing and it was at 0.. :confused: I advanced the timing and the tapping sound got less.. Still there but no where near as loud. I just had the carb rebuilt.. Has anyone ever heard tapping from the carb?
Old May 24, 2002 | 11:42 AM
Fevre's Avatar
Fevre
Noises can travel through the engine so you may be hearing a noise coming from somewhere else. I had a rod knock that was very light but could not figure out what it was until it became a banging noise then there wasn't much doubt. :( Keep an eye/ear on it. I am thinking of getting one of those stethescopes for engine use so I can pinpoint any noise I hear that is out of the ordinary.
Old May 24, 2002 | 11:46 AM
kgraumann's Avatar
kgraumann
My engine started tapping for no reason on the passenger rear cylinder. I tried to adjust the rockers, but still tapped.
This is the way I was taught to adjust if they were solid lifters.
But I finally had to pull the intake and lifters. Found out I had collasped a lifter on the exhaust side of the back cylinder.
So I rounded up enough money and changed the engine to my current ZZ4 configuration. I saved the engine for a rebuild, in case I wanted to put it back in someday.
Old May 24, 2002 | 11:49 AM
Fevre's Avatar
Fevre
Default Re: Tappers (kgraumann)
That is for hydro lifters only, solids need to be done with the engine off and using a feeler gauge. Probably why the lifter collapsed, valve hit piston.
KorbenDallas's Avatar
KorbenDallas
What is involved in replacing a collapsed lifter? I think I have one that is collapsed too.
Old May 24, 2002 | 12:12 PM
Koz
Guest
Posts: n/a
Default Re: Tappers (Fevre)
How do I know if I have hydro or solids lifters? I just loosened until I heard tapping and then tightened back the same number of turns. It was more like 1/2 turn after tapping stopped.. Why would it be different with solids?
Old May 24, 2002 | 12:21 PM
Koz
Guest
Posts: n/a
Yup.. That's what I'm affraid of.. I told the wife I need new spark plugs and decided it was too big a job and I'm going to replace engine with a crate ZZ4.. :lol: :lol: All she wanted to know was how much.. :lol: I want to drive the car through the season and by winter I'll know if I want to build up mine or buy the ZZ4. So far I haven't heard anyone not happy with a ZZ4.. but for now I'm not ready to switch..
Fevre's Avatar
Fevre
OK now we have reached the end of my knowledge on solid/hydro. I am sure there is a way to tell without tearing the engine down but I don't have the answer. IF you have the original stock engine and know for a fact no mods then its hydro but if you are unsure then check into it. I am sure others will post a way to tell em apart.
Old May 24, 2002 | 12:31 PM
Barry's70LT1's Avatar
Barry's70LT1
Solid lifters are as their name says. They are a SOLID chunk of metal. They are only drilled for providing a path for oil up the push rods to the rockers.
Hydraulic lifters have an outer casing and an inner piston, along with a spring and some valving. When you adjust the lifters and take out the tapping and then turn an additional 1/2 turn, you are really compressing the inner piston.
When people say they have a collasped lifter, it's just the inner piston has become "stuck" in the lifter casing. Usually from dirty oil or from using cheap oil.
The reason for using hydraulic lifters is to provide a quiet trouble free valve system. The inner piston sort of floats in the lifter, using the engine oil pressure.
Solid lifters have no piston to compress. If you tighten a 1/2 turn after clicking, then you will permentantly open that valve. Thats why you need to adjust the gap with a feeler guage.
Barry
Old May 24, 2002 | 12:42 PM
kgraumann's Avatar
kgraumann
Huh, I never did any adjustment before the lifter collapsed. :confused: This is the same setting it had for the 3 years I owned it, I never adjusted anything before the lifter collapsed.
Old May 24, 2002 | 12:46 PM
Fevre's Avatar
Fevre
I was assuming you had solids and did the adjustment then had the lifter failure. My bad.
Old May 24, 2002 | 02:32 PM
john's '81 mouse's Avatar
john's '81 mouse
Koz:
Are you really certain that your noise isn't a leaking exhaust manifold gasket????? These will make a noise very similar to a loose rocker arm......a ticking like noise that increases with rpm increases, sometimes a crack in exhaust system can do the same, but these usually are worse when engine is cold, and then quiet some after metal gets hot and expands to make the crack smaller. Just a thought.
Old May 24, 2002 | 03:52 PM
Koz
Guest
Posts: n/a
Default Re: Tappers (john's '81 mouse)
BINGO!!! I just got back from the mechanic who did the carb work.. Doesn't if figure.. Yesterday there was no choke at first startup, burping at WOT and today she starts like she should, no burping.. I felt bad bringing her in but as I got his shop the tapping got worse.. I said, "You hear that".. He said Yup.. You have exhaust gaskets on your manifold and it's cracked right there.. Here's a 3/4 in piece of gasket missing.. DAMM... I wish I would have found that.. He's a friend so I didn't feel too stupid but he said it was very common.. Said I should just do metal on metal like GM intened it to be.. He also said if she starts acting up and burping to check and see if the choke released the secondaries. Even though she's warm the choke could be sticking.. So, as usual... it's sunny and warm and the vette is cooling in the garage waiting to be worked on.. Oh well.. I still love her.. Thanks to everyone for your help and advise.. :cheers:
To Tappers
