76 Horns...What note??
Old May 23, 2002 | 08:36 PM
wes76's Avatar
wes76
Default 76 Horns...What note??
I think that there are two horns up front on my 76, none are working, I was wondering which note or notes to replace with, or does'nt it matter?
Thanks for any comments... :cheers:
Old May 23, 2002 | 08:43 PM
BlkBird's Avatar
BlkBird
Default Re: 76 Horns...What note?? (wes76)
Wow, you can get horns that play different notes? :confused: Get one of those from JC Whitney that play that "Dukes of Hazard" thing!... :jester
Old May 24, 2002 | 09:34 AM
KenSny's Avatar
KenSny
My '75 came with two horns (one is a dealer installed option). I read in one of the manuals that when you have dual horns they should be different "notes". I know that the dealer installed one is a "D", not sure what the other is because I can't get a good look at the lettering.
Old May 24, 2002 | 12:30 PM
Vmc's Avatar
Vmc
Default Re: 76 Horns...What note?? (KenSny)
I think the other is "F" this is real common.....
Old May 26, 2002 | 04:11 AM
Kenzy's Avatar
Kenzy
Default Re: 76 Horns...What note?? (DCTC)
Did they just quit or did one go then the other?
I thought mine were toast but it ended up being the contacts in the steering wheel button. Popped it off and cleaned them up and that was that.
Try a voltage meter to see if your getting current to the horns or try run a jumper wire to each horn just to verify that they are gone.
[Modified by Kenzy, 8:52 AM 5/26/2002]
Old May 26, 2002 | 01:00 PM
wes76's Avatar
wes76
Default Re: 76 Horns...What note?? (Kenzy)
Thanks all for the input..
Horns now work, I found that the receptacle on horn number one was not making contact, alittle cleaning and all is well. :eek:
:cheers: :cheers:
To 76 Horns...What note??
