Have a problem with my A/C....
Old Jun 6, 2012 | 09:32 AM
htown81vette's Avatar
htown81vette
Default Have a problem with my A/C....
This tube is cracked, allowing my freon to escape. Is there anyway to repair this cheaply? Please tell me what I want to hear...
By the way, this photo is not of my car, I borrowed it from another forum member, hope they don't mind...
Old Jun 6, 2012 | 10:01 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Obviously the hose is toast so I'd replace it along with the accumulator which requires replacement whenever the system is opened, and orifice tube. This is assuming there is nothing else wrong with the system. I don't know what cheap is to you but it sounds like you'll have to take to a shop so you're probably looking at $250 for the above parts plus refrigerant, R12 is more expensive but does a better cooling job, and labor. Don't scrimp on the repair because if it's done correctly, you should have years of trouble free service. Good luck.
Old Jun 6, 2012 | 10:32 AM
htown81vette
$250 sounds reasonable, thanks
Old Jun 6, 2012 | 10:46 AM
Jud Chapin's Avatar
Jud Chapin
You're welcome. $250 is just parts which may be a little high depending on the shop. You can buy the parts yourself from one of the Vette parts vendors and they would run in the $160 area. I checked the hose and it was around $85 and the accumulator and tube another $75. Of course a shop will mark up the parts. R12 freon can be purchased on Ebay for $25/can or so.
Old Jun 6, 2012 | 11:13 AM
htown81vette
Is this the hose:
http://www.ecklerscorvette.com/corve...1979-1982.html
Old Jun 6, 2012 | 11:26 AM
Jud Chapin's Avatar
Jud Chapin
According to Ecklers, that's the compressor hose and should fit the car.
Old Jun 6, 2012 | 11:28 AM
htown81vette
I see what you did there
Thanks...
Old Jun 6, 2012 | 10:08 PM
terry82's Avatar
terry82
some shops can make a hose for you .that could be cheaper .i would get estimates at two places before you bought anything.
To Have a problem with my A/C....
