HP and torque......explanation.
Old May 24, 2002 | 03:41 AM
Dalannex's Avatar
Dalannex
Default HP and torque......explanation.
Somebody posted a link to a website once that went into detail in layman's terms how and why HP and torque always meet at 5280????? (I think) RPM and what exactly both mean, as well as the history of HP and torque and how it came to be that we measure both. Does anybody have this address for me? I would appreciate it. I wanted to give it to a friend who was asking about such things. Thanks.
-Justin
Old May 24, 2002 | 08:04 AM
45ACP's Avatar
45ACP
Default Re: HP and torque......explanation. (Dalannex)
This one? http://www.vettenet.org/torquehp.html
Old May 24, 2002 | 10:46 AM
SuperFast80's Avatar
SuperFast80
Default Re: HP and torque......explanation. (45ACP)
Torque is the only thing that a driver feels, and horsepower is just sort of an esoteric measurement in that context.
Old May 24, 2002 | 11:04 AM
68shark's Avatar
68shark
Default Re: HP and torque......explanation. (SuperFast80)
Question re gross vs net. I know (roughly) how to take rwhp and work up for drivetrain losses to get "net" rating, then difference from "net" to "gross" using the '71 era numbers as a guide. Stupid question but does the same math work for torque?
In other words if an engine should produce 360 lbs of torque, do you work your rear wheel torque back up using the same calculation? I presume you would, but want to check.
Thanks!!
Old May 24, 2002 | 01:35 PM
Dalannex's Avatar
Dalannex
That's the site. Thanks 45ACP. We were talking about HP and torque and a friend was wondering many things about what each mean, and how it came that we calculate them and so on, and I thought of this site. I figured it would be the perfect way to answer his questions. It's good reading for the rest of us as well. :cheers: See, there are a lot of good things on the internet. :chevy
Old May 24, 2002 | 03:45 PM
73-454's Avatar
73-454
Never forget this rule " Torque wins races and HP sells cars. Torque is the real work horse
Old May 24, 2002 | 03:49 PM
Rockn-Roll's Avatar
Rockn-Roll
That link was very informative. However, I must point out that talking torque vs HP is like apples and oranges. Torque is a measure of the angular acceleration, while HP is a measure of the linear acceleration at a given rpm.
Old May 24, 2002 | 09:58 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Default Re: HP and torque......explanation. (68shark)
Doug, if I understood your question correctly, the answer is yes. At a given rpm, the only variable that determines the hp is the torque at that rpm. If you know the rear wheel torque, you can use the same methods to make a "guestimate" of the gross rating.
As far as torque and hp being different things, they are but keep in mind that you can't have hp without having torque. Though it's possible to generate torque without rpm (and therefore no hp), that torque would not be doing any work. Torque by itself is a measurement of the potential to do work, hp is a measurement of work that is possible.
To HP and torque......explanation.
