There was a thread on here a week ago on the same question. Ppl were saying about 500-600 as long as u don't dog it. Of course an auto will handle more than a manual
From: Graceland in a Not Correctly Restored Stingray
How much one attempts to put thru a stock 10-bolt and how much abuse it will take are different issues, entirely.
FWIW, don't have any hard HP/TQ numbers, but the revised 427 BB going back in my shark is modeling up to be ~590 HP / ~530 TQ at the crank, and I wouldn't think of putting a stock 10-bolt behind it, as I learned long ago that you don't necessarily have to be drag racing and/or on slicks to break a 10-bolt. ...and, I've broken a couple of them behind autos too.
700 hp to a stock diff? How about the aluminum (ie; '81 w/ an automatic and 3:08 gears)? I've heard that the aluminum can handle up to about 400hp and then it's a gamble after that. Some input from experienced guys, please. Thanks in advance... And: is that 400hp at the crank or at the back wheels? Thanks again.
Just so you're aware, you can mate an iron 10-bolt IRS hoghead up to the late C3 batwing.
Yes, I am aware of that. I was asking the question, as I have the stock rear and 3:08s and have made afew upgrades to my engine and intend to go into the engine sometime after the summer. Just was wondering how much abuse a rear like mine can take and if the HP guys are talking about, approx. 400, is crank shaft or rear wheels. I'm thinking crank, but not f/ sure. Thanks again in advance.
Motorhead is pushing 600 HP in front of a TKO 600 and running a stock aluminum rear end. Before that he ran a 500 HP 406 for over 25,000 miles. Same rear end. Seems like some last well and some come apart easily. Luck of the draw I guess. Run it till it breaks and replace it with something stronger or send it to Tracdogg for a buildup.
tracdogg2 has a web site, percision corvette differential.
The vette in your signature looks pretty sweet, what does it turn?
9.90's on motor, with a best of 9.78@137mph. On spray 250 shot 8.66 @156 best.
It's currently set up for 10.50 heads up. Ran this weekend and ran 10.507 and 10.488 @ 134mph I take out 9deg. of timing and run a 6inch. air filter to slow it down for the 10.50 index. Lost first round on a red light. Pushed it thru the lights on the brake.
Dave
Thats Way awesome bro! What fuel you run on for the 9 sec and 10.5 sec times?
