LS7 build started
Old Jul 8, 2012 | 01:43 PM
MR NICE's Avatar
MR NICE
Originally Posted by nonracer
Im not telling you NOT to check piston to valve clearance but I bought an LS7 from GM had the heads surfaced,decked the block,used all the stock parts like you have and put in an Ultradyne cam ( now Bullet Cams). I dont remember what the actual clearance was but it had plenty I degreed the cam to the spec card and also ran it 4* advanced.
I dont know the part # but here are the specs
264*@.050 int
268*@.050exh
.670 lift int/exh
110* lobe
My combo made 625 peak hp @ 6600 on an engine dyno
I had no issues with head gaskets using the stock head bolts and FelPro HP gaskets but I always ran race fuel
This was in a 3400lb camaro with 10" tire leaf springs and slapper bars I ran a 4200 ATI converter with a TH350 and 4:10 gear it ran high 10.30's @ 130
ill be happy to run any kind of 10's lol going in a 78camaro, short block will be done this week changed plans on solid roller went with Comp Cam Nostalgia ZL1, flat tappet solid, cam specs are 262/272@.050 581/622 110 ls any thoughts on that cam choice? anyone know of someone running one?hope its nasty lol
Old Jul 8, 2012 | 03:23 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Yes. Here is the reeeeeeaaalllyyyy long build thread. Solid roller, better heads and intake would be my choice.
http://forums.corvetteforum.com/c3-t...ld-thread.html
There is a dyno video toward the end. If your using it I would also use beehive springs as the recommended spring rates were not adequate for high rpm use.
Old Jul 17, 2012 | 10:02 PM
MR NICE's Avatar
MR NICE
short block pic
http://i31.photobucket.com/albums/c3...rusher/014.jpg
Old Sep 2, 2012 | 07:57 PM
MR NICE's Avatar
MR NICE
Any guess on the hp torque output?
Old Sep 2, 2012 | 11:32 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
The stock LS7 solid flat tappet cam, pn 3959180, has 262/273 degrees at .050 ground on a 110 lsa and gross lift of .556/.594 with 1.7:1 rockers.
Your cam choice is very close to stock and will run & sound great!
E85 works great!
Old Sep 3, 2012 | 12:56 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
LS-7's were killer bracket race motors. Used to mess with them all the time. The old Crane R262 and similar series cams with .714" lift worked well in them. I'd probably use a 108 or so LSA if I was going to have good fuel anyway to help wake it up some more.
JIM
Old Sep 3, 2012 | 02:29 PM
MR NICE's Avatar
MR NICE
I'm having a hard time deciding which valve springs to runCalled comp cam 3 times different advice all 3 times, anyway so far 924 spring, 930 spring,and a bee hive spring that is good to 590.lift?my cam is 622 lift on the exh with .012 for lashwhat do you guys think i should do about this?any suggestions?
Old Sep 3, 2012 | 08:37 PM
larrywalk's Avatar
larrywalk
The stock springs for the GM LS7 (pn3959180) cam are 1.487" OD, and 116# at 1.88", with coil bind at 1.100"; and a rate of 317 #/in. These were spec'd for the L88s, ZL1 and LS7.
For any other cam manufacturer, better check with them.
Old Sep 3, 2012 | 10:59 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
That's just gonna be a nasty race motor, have fun in traffic. Have they found a way to keep the valve out of the cylinder if a beehive spring breaks, I would never use a single spring
Old Sep 3, 2012 | 11:38 PM
cv67's Avatar
cv67
St. Jude Donor '05
Unless its a stock or very mild cam forget beehives. I always run a tad more spring pressure than called for to help idiot proof things.
Old Sep 4, 2012 | 11:27 PM
junkman123's Avatar
junkman123
so just what kind of compression will E-85 run on,i have about 12:1 and struggling with a de-tune to run 93
Old Sep 6, 2012 | 10:23 PM
MR NICE's Avatar
MR NICE
ive read 14 to 1? i will be around 12.5 to 1, going to run 106 octane leaded gas for break in then go with e 85
Old Sep 18, 2012 | 10:48 AM
  #33
MR NICE's Avatar
MR NICE
going with 930 comp springs,thats whats on the cam card
Old Sep 18, 2012 | 11:27 AM
  #34
DRIVESHAFT's Avatar
DRIVESHAFT
Using the springs recommended on the cam card is always a wise choice.
