Blinker won't work with head lights on
Old Jun 12, 2012 | 10:19 AM
73 454's Avatar
73 454
Default Blinker won't work with head lights on
My driver side blinkers won't work when my head lights are on. Has anyone else had this problem? or have an idea of what's going on?
Also the bulb holder doesn't hold the bulb tight enough to create a good connection with the blinker bulb on the driver side. is there a way to replace the wire/connector so it will hold the bulb tight again?
Old Jun 12, 2012 | 10:21 AM
73 454's Avatar
73 454
http://www.ecklerscorvette.com/corve...1956-1996.html
I just found this. will this fix my problem? just slide out the old worn one and replace with this or will i need to rewire it also?
Old Jun 14, 2012 | 11:18 AM
73 454's Avatar
73 454
No one has an idea why they won't work? I'd really like to have them in working order so i don't have to worry about getting hit
Old Jun 14, 2012 | 11:58 AM
Ralphbf's Avatar
Ralphbf
When someone has issues with their electrical I tell them check the ground.
I think you have more trouble than that but it wouldn't hurt.
Bad grounds can cause a lot of funny stuff to happen.
Wish I could of been more help.
Ralph
Old Jun 14, 2012 | 12:05 PM
mark6669's Avatar
mark6669
You just need front park light harnesses ecklers part# A9328, 2 new sockets & wiring pigtail should cure the problem with loose bulbs. Also check the ground connection drivers side on front of core support at lower left of a/c condenser.
Mark
To Blinker won't work with head lights on
