Replacing door WS on my 81 and on left side rear pillar, once I removed the old dry-rotted rubber and rust, I found this stainless plate glued onto the pillar (see red arrow). What is this? Is it a shim under the WS or is it something that was internal to the WS? Something else? Should I remove it or leave it there? It seems much more securely glued in than the WS was.
My first post, but have been reading many others for last 6 months or so, and really appreaciate everyone's help!
That is a weatherstrip retainer and they do not make reproductions. Not sure about later models but on my 71 its riveted in place. I cant see your photo either just going by your description.
Thanks guys. Sorry about the pic - I can see it, not sure why you can't... but anyway, I guess I'll leave it there. Doesn't seem like it wants to come out anytime soon.
I can see it now. As suspected that is the weatherstrip retainer.
...Doesn't seem like it wants to come out anytime soon...
There could be rivets or screws on the backside. The assembly instruction manual (AIM) shows how it was installed. I am guessing you will also find factory sealant under it.
I have 78; the new weather strip I bought from Davies has metal reinforcement strip molded inside new pillar weatherstrip piece. I removed the metal strip (popped off rivets); now new piece fits nicely. Unless your new weatherstip has no metal in it;then this strip of metal has to be removed. Just saying...
