HELP!!! Fish eyes in dp.
Old May 24, 2002 | 02:03 PM
ImBatman's Avatar
ImBatman
Default HELP!!! Fish eyes in dp.
Well I am back on the job at day two and I am having a problem with fish eye in 5 spots on the deck lid. The first time it happened I squirted the areas down with the dx330 and then roughed them up with scotch brite. I then re-shot the area and there they are again so this time I sanded the areas and then applied a liberal amount of dx re-shot and again in the same place. Tried a third time with the same results in the exact same areas. What gives am I doing something wrong? Every other peice has sprayed fine. :mad :confused: :smash: :crazy:
Old May 24, 2002 | 02:10 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Default Re: HELP!!! Fish eyes in dp. (wadew10)
I'm sure you'll get some other ideas but my 1st thought is to get out the dremel tool and carve/grind a small hole/crater in each of the spots, apply vette filler, sand and reshoot. I had 2 maybe 3 spots that had fish eyes on my nose I just painted and that's what I did and everything seemed to seal up fine after I removed a little material.
Keep us posted with the solution that you get to work.
Old May 24, 2002 | 03:38 PM
Rockn-Roll's Avatar
Rockn-Roll
What do "fish eyes" look like? There's some "bubbles" on my drivers door...I've been thinking about sanding them down and hoping it doesn't sand all the way to through the basecoat.
Old May 24, 2002 | 03:41 PM
SteveA's Avatar
SteveA
Before you start grinding, try this. Clean out the areas with reducer on a rag...remove all the fisheyes/DP. Let it dry some. Feather it out a bit with 400 (easily), scuff the surrounding areas with scotchbrite & clean with dx again. Dont soak the area with dx. When you clean with this, wipe the area then follow up and dry the area with a clean & dry paper towel. The first pass applies the cleaner, the next pass removes the contaminents. You probably have too much dx residue in the area. Next spot the area with DP using thin coats by triggering. Dont apply the stuff too wet.
Old May 24, 2002 | 03:49 PM
ImBatman's Avatar
ImBatman
Default Re: HELP!!! Fish eyes in dp. (SteveA)
Thanks for the replies. SteveA you are probably right I may have gotten a little DX happy. I will try your suggestion and let everyone know how this works out. I have the panel really straight and don't want to start grinding on it unless I absolutely have to. :cheers:
Old May 24, 2002 | 03:54 PM
SteveA's Avatar
SteveA
Default Re: HELP!!! Fish eyes in dp. (Rockn-Roll)
Are they raised or sunken? If they are raised the paint is probably lifting or rust/moisture is forming underneath. Sanding wont fix. Fisheyes are sunken craters that appear when applying paint due to the paint pulling away because of contaminents on the surface.
Sorry ...this reply was meant for rockn-roll......
[Modified by SteveA, 7:58 PM 5/24/2002]
Old May 24, 2002 | 03:57 PM
SteveA's Avatar
SteveA
I'm glad its friday....
Old May 24, 2002 | 05:09 PM
74-Roadster
St. Jude Donor '06
The crater I was trying to describe should be no more than 1/8" in diameter and 1/16" deep. Use a dremel tool to create a small hole to hold a dab of filler. I did this to my nose after it was really claen and straight and the DP and K36 were both in place. It's a very quick and easy solution. By cleaning all of the DP off in that area and feathering etc. you'll end up with a large diameter low spot that will need to be filled somehow . . .
Old May 24, 2002 | 05:27 PM
SteveA's Avatar
SteveA
Default Re: HELP!!! Fish eyes in dp. (74-Roadster)
The DP should not be that thick. By lightly feathering,scuffing and cleaning the surrounding area after dabbing & removing the fisheye, the surface should still be level enough after spotting it in where the subsequent surfacer and blocking will take care of the leveling of the surface for finishing. The less filler the better.
Old May 24, 2002 | 06:26 PM
Rockn-Roll's Avatar
Rockn-Roll
Thanks...got it. My bubbles are sticking out (outies), does this mean I have rust in the door? Is the door steel? I thought all of the body was fiberglass?!?! :confused:
Old May 24, 2002 | 06:55 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Let me tell you what I have learned from Lars and what I experienced last year when I painted my car. Fish eye is caused by silicon, the only thing dx330 WILL NOT remove is silicon. I found that oil like from your skin will cause wrinkles instead of fish eye. I tried using a silicon remove my paint store had called polycracker. I dont find that this worked as well as expected, but after several coats of base in the same area, around the driver side fender, they went away. The grind trick mentioned above will probably work, just sanding won't, but a good silicon remover should do the trick.
To HELP!!! Fish eyes in dp.
