Power to the trans an diff
Old Jun 13, 2012 | 04:20 PM
MajD's Avatar
MajD
Default Power to the trans an diff
I have a stock '79 with a Borg-Warner four speed. I'm fixing the car up and while I want to keep it mostly stock, I am thinking of going with a stronger engine. As part of the project, I've had the transmission and differential rebuilt. I had the rebuilds done with OEM or OEM replacement parts, so nothing has been upgraded. I do not plan on racing the car or dumping the clutch at high RPM, I just want the thing to come to life when I step on the gas. I was thining 350 - 400 hp should to do the trick, but wanted to know what a good estimate is for the amount of power the stock tranny and diff can take. I suspect the tires will break traction before the rear end and tranny blow out. I may also go with a wider tire in the rear, but probably nothing bigger than 245. Thanks.
Dan
Old Jun 13, 2012 | 04:22 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
This is already being discussed here:
http://forums.corvetteforum.com/c3-t...ferential.html
Old Jun 13, 2012 | 07:36 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Dan
With 245 tires and <400 Hp no problem.
To Power to the trans an diff
