C3 aftermarket wheels....
Old May 15, 2013 | 11:42 AM
scottyp99's Avatar
scottyp99
1000 lbs. of engine? What did you do, swap a bus engine into the thing?
Scott
Old May 15, 2013 | 12:25 PM
MikeKey's Avatar
MikeKey
Originally Posted by Tangelo79
Thank you front and rear spoilers are the factory D80 option. Your car looks great with the wheels and side pipes bet it is a rare sight and gets lots of attention in Sweden!!
What color is that beautiful orange if I may ask? I just can't stop looking at it.
Old May 15, 2013 | 12:55 PM
Tangelo79's Avatar
Tangelo79
Thank you it is House of Kolor - Tangelo Pearl Metallic
Old Dec 16, 2013 | 09:46 AM
3 or 88's Avatar
3 or 88
My daughter has a 76 and I am trying to purchase her a set of rims that she likes "Foose Legend" This is what I have so far wondering if I could get some info on if these will work;
For the front 18x8 w/ 5"backspace (tires 245/45-18) and the rear 18x9.5 w/ 6.60"backspace (+1-5/16" offset) (tires 285/40-18)
I would appreciate any advise or help to make sure this will work properly
Old Dec 16, 2013 | 11:14 AM
jb78L-82's Avatar
jb78L-82
Just for comparison, 255/45/17 ZR's in Front and 255/50/17 ZR's in the rear.
[IMG][/IMG]
Old Dec 16, 2013 | 06:01 PM
diehrd's Avatar
diehrd
[IMG][/IMG]
What mufflers are you using
Old Dec 16, 2013 | 06:03 PM
jb78L-82's Avatar
jb78L-82
Monza Turbos.
Old Dec 16, 2013 | 09:55 PM
3JsVette's Avatar
3JsVette
Too much backspace. The front you want 4" backspace for a 8" wheel (although 4.5" will work). In the rear you want 5" backspace for a 9.5" wheel. If you buy those wheels you will need "adapters" to make them work. I would pass till I found something I like with the correct backspace.
Old Dec 16, 2013 | 11:08 PM
3 or 88's Avatar
3 or 88
Thank you for the info.
Old Jan 29, 2014 | 05:02 PM
TedH's Avatar
TedH
What backspacing is required with a 17x8 wheel? Same 4" backspacing as my 15x8 wheels?
I am eying the 255-50-17 tires on AR 105M Anthracite 17x8 wheels.
Old Jan 29, 2014 | 10:44 PM
vetteman1981's Avatar
vetteman1981
You had a question about the offset on a C3 wheel? I believe it is -12mm offset. If I am wrong please correct me guys.
Try this link.
http://www.mrw-wheels.com/wheel%20te...t%20chart.html
Old Jan 30, 2014 | 12:55 PM
cottoneg's Avatar
cottoneg
Buy a wheel that you can specify the offset. There are a number that you can. Unless you have a specific rim and mind.
