* * * H E L P * * * Major Misfire
So let me fill you in, it's been a long journey, had all 3 carbs redone on my 427/400 4spd. Car ran a little rough before, stalling when making a hard right turn, & minor misfire. The carbs needed to be redone anyway and recolored etc..........so after they were done & installed, I developed a M A J O R - M I S F I R E - runs like crapola, sounds & feels like running on 5 cyl not 8. Checked compression, cyl 1= 155 all the rest are 170 -175 except one at 165 - changed all plugs, ( none were fouled ) new cap, rotor, points, wires, & new coil. Still runs like crap, rough idle, stalls like it's cold,backfires through exhaust when I let off the gas, & i smell gas with NO leaks anywhere in the garage after turning it off at night & returning a few hours later at times. Runs decent at high RPMS on the highway, but not at low speeds or idle. Also thinking if it had an internal bad air leak it would smoke.....there is NO smoke anywhere EVER !
If you put your hand over the center carb it smooths out at idle. WOW was thinking vaccume leak. My carb guy that redid them came over & changed the power valve, ( didnt do it ) & took the center carb off to have it flow / bench tested, thinking only other internal carb related thing could be the metering block, After looking down the carb at ilde not much gas is coming through the venturis / when you place your hand over it it flows better...... thinking possibly NOT the carb now, but an internal vaccume leak possibly, we tested it at the manifold, and pulled 15, but it moved up to 25 when coving the center carb...........we sprayed carb cleaner around the base & manifold the old fashion way searching for air but there was nothing obvious. At the time the carbs were replaced, the rear one was not sittting poerfect on the manifold, showing a liitle warping possibly in the aluminum intake, but not really bad, nothing 2 gaskets didnt / couldnt cure & not leaking air there after spraying either.
What do you think ? ideas ? suggestions ? where would you go next ?
1. Timing ?
2. Distributor ?
3. Warped / cracked intake manifold ?
4. Still carb related internal ? or the 2 outboards ?
5. L A R S ??? where are you ............?
Dan
If there is a gap, then fuel is being drawn into the engine above and beyond it's need. Take the mechanical linkage off and go through the entire process of reseting it slowly step by step per the book. If that doesn't fix the problem let me know.
Check your PM box
Dan
EDIT:
Timing must be checked to insure it is not an issue. If you have fresh 93 octane in the tank, then set initial timing to 14* to begin with. If you don't do this first, other issues will become very difficult to discover. As Roger has said you must also be running the correct center carb gasket as well as the end carb gaskets. I am assuming you have all of the correct parts and all the correct parts installed correctly. The gaskets have a specific orientation that must be right.
So, if you are certain all the right parts are there and they are all installed properly, it's a simple step by step process to solve your issue. Check your secondaries to be sure they are closed and check your timing, then we can go from there.
Well now i'm also wondering if it's correct or not ???
I found my broken spring visually and by touch.....
One spring looked a little shorter and I could turn it by hand until
I saw where the spring had broken.( I was lucky)
I was also confused what the 2 outer carbs have to possibly do with this, since it only idles on the single center carb & when i cover it, it smooths out. Some said to make certain the 2 outers are closed at idle....?
Covering the carb is like closing the choke it richens the mixture and will compensate for a vacuum leak.
CORRECT ??
