Steering Column Alignment
Old Jun 15, 2012 | 06:27 AM
ABinAUS's Avatar
ABinAUS
Default Steering Column Alignment
My Steering column seems to be mounted out of centre (twisted), the ignition and indicator stem are not parallel to the dash. Before I pull everything apart any suggestions on what I need to do to align things correctly>
Old Jun 15, 2012 | 07:01 AM
Marlin's Avatar
Marlin
You have pictures?
If its the entire colum check the 2 bolts under the dash that hold the unit up.
If its tilited part way up then could be the one/some of the shaft bearings.
Old Jun 15, 2012 | 07:10 AM
Jim Shea's Avatar
Jim Shea
The 1969 through 1982 Corvette steering columns (both non-adjustable and T&T versions) have a welded bracket where the two vertical bolts hold the column up into the dash structure.
So it would seem difficult that any adjustment can be made to change the rotational attachment of the column to the instrument cluster.
This scan of a straight on view of a 1977 T&T Corvette column shows the turn signal and the tilt levers to be horizontal. This 1977 picture is typical of all the other C3 steering columns.
Jim
Old Jun 15, 2012 | 08:18 AM
...Roger...'s Avatar
...Roger...
Jim
Its possible the welded bracket was removed and reinstalled or not connected at all. It could be improperly installed in some way, something stuck between the bracket and mount for instance.
If the column has been apart ,its possible the upper housing is not clocked correctly,this would not be good because to do so probably damaged something.
I think to help much more we would need more info after you have removed the bottom trim and investigated a bit.
Old Jun 15, 2012 | 08:45 AM
ABinAUS's Avatar
ABinAUS
Mmmm .. sounds ominus.
Old Jun 15, 2012 | 10:59 AM
Jim Shea's Avatar
Jim Shea
There should be two aluminum capsules (one on each side of the steering column.) The vertical column installation bolts pass through the capsules and attach them to the dash structure. The capsules were designed to slide off of the steering column mounting bracket in a severe frontal collision and allow the column to collapse on itself and absorb energy. Is it possible that one of the capsules is missing and Bubba just clamped the bracket to the dash structure causing it to tip to one side?
I doubt that the upper bracket on the steering column has been removed. It was typically welded pretty securely because it was constructed of fairly thick material. The thin sheet metal bracket down by the floor pan probably could be removed or rotated by grinding the spot welds.
I hope that your car was not in a severe enough collision so that the dash structure was damaged and caused the problem.
Jim
Old Jun 15, 2012 | 11:18 AM
Jim Shea's Avatar
Jim Shea
This is from the 1976 Corvette AIM but it is very close (or the same) as all of the C3 column installations. You can see two big stamped brackets (A and C). Those two brackets can be shifted around so as to make the steering column concentric to the hole in the instrument cluster. I haven't really ever played with repositioning those two brackets. And I am not really sure that they would have any affect on causing the steering column to be tipped to one side or the other.
Jim
Old Jun 15, 2012 | 05:25 PM
ABinAUS's Avatar
ABinAUS
Hi Jim, thx .. there are no signs of collision damage. The only signs are of a break-in (damage around door lock, glass fragments inside door) .. I had suspected the twist was caused by someone trying to break the steering coloum lock by reefing on the steering wheel).
Alan
Old Jun 15, 2012 | 08:09 PM
ABinAUS's Avatar
ABinAUS
does anyone have any photos on what it should look like?
Old Jun 15, 2012 | 09:21 PM
...Roger...
How about photos of what your column looks like.
Old Jun 15, 2012 | 09:33 PM
ABinAUS's Avatar
ABinAUS
Hi Roger, I havn't pulled things apart yet .. was hoping to do this today but its raining cats and dogs, have to do any work outside as not enough room in the garage
Old Jun 15, 2012 | 10:54 PM
Jim Shea's Avatar
Jim Shea
Oh, a thief possibly was reefing on the steering column head or on the steering wheel. My gosh, maybe that could explain the slight amount of rotation of the upper end of the steering column!
There are four screws that hold the support to a lock plate that is supposed to be cam locked into the upper jacket. I would suggest a tear down of the steering column head to determine if the lock plate has been disengaged from the opening in the upper jacket.
jim
Old Jun 16, 2012 | 12:13 AM
ABinAUS's Avatar
ABinAUS
Hi Jim, I now have a photo og the steering wheel .. not sure how to post it in the thread?
Old Jun 16, 2012 | 12:22 AM
ABinAUS's Avatar
ABinAUS
[IMG]D:\My Documents\My Pictures\2012_06_16\IMG_6367.jpg[/IMG]
Old Jun 16, 2012 | 07:20 PM
ABinAUS's Avatar
ABinAUS
Hi Guys, Here are the lings to the photos:
Alan
Old Jun 16, 2012 | 08:26 PM
...Roger...
Not good , somethings not right. Try loosening the 2 bolts and see if the column is still attached to the bracket.
Old Jun 16, 2012 | 10:44 PM
Jim Shea's Avatar
Jim Shea
The driver side and the passenger side wings on the steering column mounting bracket should be in-line with each other. The wing on the driver side is noticeably bent. Here is your answer as to why your turn signal and tilt levers are not horizontal.
I'm surprised that someone could reef on the steering wheel so hard that they could bend that ear. I don't know how you are going to be able to bend the driver side ear back to straight. Maybe you can stack some shims, use a longer bolt and get the column with its levers back to a horizontal position.
Jim
To Steering Column Alignment
Old Jun 17, 2012 | 04:25 AM
ABinAUS's Avatar
ABinAUS
Ah well .. I'll try the shims or its going to be one of those jobs to do when I convert it to RHD later this year.
Jim and roger thx very much for your advice,
Old Jun 17, 2012 | 07:27 AM
Jim Shea's Avatar
Jim Shea
I scaled one of my assembly drawings and it appears that the left (driver side) mounting capsule is about 0.10 inch lower than the right side capsule. From your pictures it does appear that the left side is quite a bit lower than just 0.1 inch. So disregard my previous statement that the two capsules were in-line.
Jim
Old Jun 17, 2012 | 08:22 PM
ABinAUS's Avatar
ABinAUS
Hi Jim, Thx for the update .. must have taken some force to twist. Alan
