Engine code 195705739 VT0T7HX
Old Jun 16, 2012 | 03:18 PM
Limey1955's Avatar
Limey1955
Default Engine code 195705739 VT0T7HX
Hello all,
I have a 1969 coupe, 350 4-speed which I believe is the 350HP engine type. On the front right of the block are stamped the codes in the title to this thread. I've tried to ID the engine without success. Can anybody help? The center console in the car does identify it as a 350HP 11:1 compression engine but I want to be sure.
Thanks,
Phil
Old Jun 16, 2012 | 03:41 PM
Mike Ward's Avatar
Mike Ward
The 195705739 should match the VIN of the car.
The VT0T7HX is probably V1017HZ
V= Flint MI engine plant
1017= engine assembled October 17
HZ= 1969 base engine 300 HP with auto transmission.
Old Jun 16, 2012 | 05:02 PM
restoman1's Avatar
restoman1
195705739 VT0T7HX
More than likely it's 19S705739 which like Mike said, should match your VIN.
V1017HX would be a 350/350 with 4 speed and A/C. Do you have both of these?
Ed
Old Jun 16, 2012 | 08:48 PM
Limey1955's Avatar
Limey1955
Yes - I have both 4spd and AC. Looks like it is a 350HP. Thanks very much for the feedback.
Old Jun 16, 2012 | 09:39 PM
Mike Ward's Avatar
Mike Ward
OOps- don't know where I got HZ from. Sorry about that. HX is a 350 HP
Old Jun 17, 2012 | 12:15 AM
Limey1955's Avatar
Limey1955
QUOTE=Mike Ward;1581089576]OOps- don't know where I got HZ from. Sorry about that. HX is a 350 HP [/QUOTE]
Thanks Mike. I asked Ed and I'll ask you too: What reference info did you use? I know there's books available from Chevy which have this information available but I couldn't find my code online.
Phil
Old Jun 17, 2012 | 12:33 AM
restoman1's Avatar
restoman1
Phil, the "Chevrolet by the Numbers" series by Alan Colvin is probably the best for engine codes, casting numbers, and a lot more. There are 4 in the series (not including the one just for Corvettes) and they're available in most restoration houses. Highly recommended!
Ed
Old Jun 17, 2012 | 06:55 AM
BKarol's Avatar
BKarol
Quick online reference:
http://www.corvette-world.com/corvet...ifications.php
Old Jun 17, 2012 | 10:16 AM
Mike Ward's Avatar
Mike Ward
Phil
I had an NCRS (Hey look- I said it and didn't burst into flames ) book next to me at the time, but there's many on-line guides that have all GM codes and not just Corvette. Knowing how to initially breakdown the alpha numeric code to extract just the machine code is important too.
This one is good:
http://www.nastyz28.com/index.php?page=chevyenginecodes
To Engine code 195705739 VT0T7HX
