Mini Starter
Old Jun 17, 2012 | 05:35 PM
AP4EVER's Avatar
AP4EVER
Default Mini Starter
Planning on replacing starter on my 81 with a mini. Any benefit over the two different designs?
http://www.dbelectrical.com/p-1304-c...-hp-mt200.aspx
http://www.dbelectrical.com/p-5809-s...sdr0031-l.aspx
Old Jun 17, 2012 | 06:39 PM
qwank's Avatar
qwank
I have the second style in my car. You can slip it in easy with headers installed.
Old Jun 17, 2012 | 08:17 PM
restoman1's Avatar
restoman1
I got THIS ONE from Skip White a few months ago and love it. The reason I got it from him was because it came with a lifetime warranty, and because I've purchased parts from him before and was very satisfied. The starter is basically the same one that everyone else sells (the bottom one in your links), but he had a good price and the lifetime warranty that no one else did.
Ed
Old Jun 17, 2012 | 08:49 PM
trw's Avatar
trw
I have the second also.
Love it, turns the 489 with 9.5 compression with no problem.
Hope this helps.
Terry
Old Jun 17, 2012 | 09:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
Love the mini starters strong light easy to install.
Would never go back to the stock style period.
Old Jun 18, 2012 | 10:26 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
The secone one has the "R" terminal on the solenoid while the first does not. You will want the second one if you have the older style points style distributor.
Old Jun 19, 2012 | 06:43 AM
AP4EVER's Avatar
AP4EVER
Thanks Ben,
You are first to answer the question. My 81 does has HEI so I can install either one. So is the first one easier to line up since the starter bendix gear is not covered by the housing. Or is it a mute point because they bolt up without any issue. Bottom line for me is that SkipWhite sells both for the same price and I'm trying to figure out which one I should order.
Old Jun 19, 2012 | 07:22 AM
Marlin's Avatar
Marlin
The first one works on both 153/168 tooth flywheels. The 2nd only works on one.
So not a big deal if you will always run the same flywheel/motor setup.
Old Jun 19, 2012 | 08:32 AM
'75's Avatar
'75
The two starters are different because of the mounting holes, make sure which you need.
To Mini Starter
