looking at corvette with shifter problem
Old Jun 19, 2012 | 12:17 AM
meticulo3366's Avatar
meticulo3366
Cruising
Default looking at corvette with shifter problem
Hello all,
I am looking at a nice 1976 corvette with a shifter problem. The owners Mechanic says it needs a new shifter and quoted $1000 in labor For the repair. I am mechanically competent so I plan on doing it myself but I was wondering what is involved in replacing the entire 4 speed shifter. I have done some googling to no avail. Any help would be appreciated.
Old Jun 19, 2012 | 01:29 AM
bluedawg's Avatar
bluedawg
You cam buy a new shifted with linkage from shift works, they owner of shift works is very helpful over the phone.
Old Jun 19, 2012 | 05:42 AM
lvmyvt76's Avatar
lvmyvt76
what is wrong with the old shifter, worn bushings or something?? Most can be rebuild and cleaned up, readjusted to be like new.
There is another post about someone with a 75 that had shifting problems, they replaced the tranny lube, and fixed their problem.
How does the mechanic know the shifter is bad, it could also be the clutch needs adjustment.
Old Jun 19, 2012 | 07:36 AM
Super6's Avatar
Super6
If the problem is truly with the shifter, you might consider an upgrade to a Hurst Competition Plus shifter. Precise easy movement, spring-loaded to neutral.
Old Jun 19, 2012 | 07:57 AM
Garys 68's Avatar
Garys 68
For $1k, I'm guessing it's internal in the trans. The whole assembly is about $300 and can be swapped out in about an hour.
Old Jun 19, 2012 | 10:58 AM
meticulo3366
Cruising
Gary68 what do you mean by "the whole assembly", as in whole shifter assembly or the whole transmission assembly. I appreciate the input so far, I will post a youtube video when I check it out later this week.
Old Jun 19, 2012 | 11:10 AM
Garys 68's Avatar
Garys 68
For $300, you can buy the shifter mechanism, handle, ****, shift rods, and shift arms, new.
To remove a trans, rebuild, reinstall with new clutch, pilot bearing will cost about $1k. What exactly were you told the shifter problem was? Synchros, sliders, forks? Those are all internal.
Old Jun 19, 2012 | 12:11 PM
meticulo3366
Cruising
He says the car cannot get into third gear and his mechanic said it needs a new shifter. Or atleast thats what I thought he said. He speaks poor english so its hard for me to understand the problem. Here is a video of the car that he has taken.
http://www.youtube.com/watch?v=QwVrDZKO4SU
Old Jun 19, 2012 | 03:49 PM
Doug Kraft's Avatar
Doug Kraft
Looks like it already has a Hurst shifter in it.
Old Jun 19, 2012 | 04:06 PM
meticulo3366
Cruising
He has told me the shifter has never been replaced in its history. But its almost 40 years old so one of the other owners could have definitely changed the shifter at some point.
Old Jun 19, 2012 | 07:26 PM
dmrodco's Avatar
dmrodco
its a auto car that someone stuck a manual trans in......pass on that beater. really it has issues you can do much better unless he is just handing over the keys and even then i think i would pass on that pile.
Old Jun 19, 2012 | 07:41 PM
meticulo3366
Cruising
thank you for the advice! How could you tell it was once an auto? I am passing on it.
Old Jun 19, 2012 | 08:04 PM
redvetracr's Avatar
redvetracr
are you sure all it needs is a shifter? and not a transmission?
Old Jun 19, 2012 | 08:06 PM
meticulo3366
Cruising
He doesnt know if it needs a shifter or a transmission so I am passing on it
To looking at corvette with shifter problem
