Starter?
Old Jun 20, 2012 | 06:08 AM
Red 77L48's Avatar
Red 77L48
Cruising
Default Starter?
Hello, friends!
Picked up our "new" 77 last night and drove it about 50 miles and stopped by the office for a minute or two. Came out and it appeared the starter would not work.
Called AAA. They tested the battery which appears to be new and it was fine. They even gave it a jump with one of those portable box things. No dice.
I've read online that my starter could be suffering from heat soak? I guess I'll know more when I get to the office in about two hours and try and turn her over.
In any event, if it's NOT the starter, what could it be? Plenty of juice for the windows, radio, wipers etc.
Thanks! I look forward to your feedback!
Old Jun 20, 2012 | 06:33 AM
Marlin's Avatar
Marlin
Don’t go jumping the gun, first start basic and work from there. Take the battery to a parts store to charge and test. Takes a lot more power to start a car then move a window.
Next check the signal wire to the starter’s solenoid when turning the lock tumbler. If its sending a strong signal then your ignition switch is ok.
Next check the voltage at the starter. Could have a bad battery cable. If there is little drop from the battery to the starter then the cable should be fine.
Next have someone turn the key and see if the voltage from the top of solenoid jumps to the other side of the solenoid terminal. If it does then the solenoid is ok.
Only thing after that is the starter itself if it is not jumping the bendix or making any sound. If its making a starting sound could be the bendix or the flywheel.
But the options for starter is a mini one (my preference) or get a oem style rebuilt model. But put a heat shield on which ever one you go with.
Also welcome to the C3 Corvette group.
Old Jun 20, 2012 | 09:05 AM
bluedawg's Avatar
bluedawg
Sounds like heat soak, might also check the ground to frame.
Old Jun 20, 2012 | 12:49 PM
69 Chevy's Avatar
69 Chevy
Why fret? If it's got a manual trans, just park on a hill, coast down or have a few helpers push, and kick start it. If you're unlucky enough to have a hydromatic slushbox, suffer!
Old Jun 20, 2012 | 01:31 PM
Red 77L48's Avatar
Red 77L48
Cruising
Well, she fired right up and that was fun. I took it out for a nice spin with a coworker around 10 or so and it fired right back up again.
However, about an hour or so ago she would not start up but it did fire up after I opened the hood and let it cool off. It's super hot here today (Cleveland) and she's parked on a freshly paved asphalt parking lot.
Starter, right? What's one run at an Autobarn (or similar)? This a good weekend job for someone who's pretty good with a wrench?
Old Jun 20, 2012 | 01:33 PM
Marlin's Avatar
Marlin
Its heat soak, another starter could have the same problem.
Either get a mini and/or get a heat sheild for the starter.
Old Jun 20, 2012 | 01:52 PM
Red 77L48's Avatar
Red 77L48
Cruising
Mini? Sorry. Not sure what you mean. And why would another starter have the same problem?
Are Corvettes only prone to heat soak? I would think with the number of these engines out there this would be a common problem?
Thanks for the input. I plan on getting her into my nice cool garage asap.
Old Jun 20, 2012 | 01:56 PM
Marlin's Avatar
Marlin
Old GM starters are prone to heat soak, its a old issue. Heat sheild and then GM going to smaller high power starters fixed it.
Mini-starter, like this...
http://www.ebay.com/itm/NEW-SB-BB-CH...42d67e&vxp=mtr
Old Jun 20, 2012 | 02:03 PM
paragonspirit's Avatar
paragonspirit
My problem with starters for a long time was a poorly fastened ground that would intermittently become 'sufficiently' loose and no longer start the car...
Old Jun 20, 2012 | 02:27 PM
wcsinx's Avatar
wcsinx
Because it's not a wear issue. Resistance increases with temperature. Get the windings hot enough, and they won't flow enough current to operate.
Corvettes have a big engine in a relatively small space. And from the factory, they came with cast iron exhaust manifolds. Let me guess, this car has headers.
Old Jun 20, 2012 | 02:32 PM
76Vett's Avatar
76Vett
Had the same problem on my 76 last year. Turned out to be the ground between the battery and frame. Made a quick trip to NAPA, $15.00 later they made me one the correct length and ends - cleaned up the area on the frame, bolted it up and haven't had a problem since.
Old Jun 20, 2012 | 02:47 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Had the same problem on my white79. Was where if I was taking it someplace I expected to be there for at least an hour.
Last time it happened was almost 2 hours so I finally looked into it.
Made sure the battery cables were tight. Didn't just check them for tightness, undid them and reattached them.
Opened up the starter solenoid.
I took a wire wheel to the edges of the disc to knock off burn marks and turned the contact in the cap 180 degrees to get a new surface(you can see the worn side).
Seems to have solved the intermittent start problems I had. No problems since.
Old Jun 20, 2012 | 03:17 PM
Red 77L48's Avatar
Red 77L48
Cruising
Great stuff, gents! I will try the ground first and foremost.
No doubt the 95+ degrees and it parked on a new parking lot are not helping today!
Love my car!
Old Jun 20, 2012 | 03:28 PM
Red 77L48's Avatar
Red 77L48
Cruising
Hmmm. That the negative terminal to the frame?
Old Jun 20, 2012 | 03:41 PM
Peterbuilt's Avatar
Peterbuilt
Try KapsSA's suggestion.
Turn #1 180* and wire brush off #2.
I've seen that work many times.
Old Jun 20, 2012 | 03:47 PM
Ironcross's Avatar
Ironcross
Follow this advice and save yourself the added layer of work of pulling a starter....My bet is its not the starter...HEAT SOAK is a phony statement for something to blame as the problem......every thing under the hood is heat soaked...don't believe me? ...open the hood and touch any part of the engine and see if its hot after running up to temp...Clean the ground from the battery to the frame as its normally the most neglected connection on a Vette and the most important
Old Jun 20, 2012 | 03:57 PM
wcsinx's Avatar
wcsinx
Every electrical junction introduces some resistance whether it's the motor brushes, ground terminals, or what have you. HEAT makes it worse. As temperature increases so does resistance. So if you have a weak or compromised connection to begin with, then if you get it hot enough it very well may stop working altogether. There are multiple ways to deal with the situation no doubt. You could either isolate those components from heat or make them more tolerant to said heat. But to flatly say there's no such thing as heat soak is really not right.
To Starter?
Old Jun 20, 2012 | 04:06 PM
Red 77L48's Avatar
Red 77L48
Cruising
Thanks all for the input. You probably saved me at least the cost of replacing the starter!
I'll start with the battery and the ground. Rock awn.
Old Jun 20, 2012 | 08:29 PM
speedreed8's Avatar
speedreed8
i had a neutral safety switch that acted like that. sometimes it would start sometimes nothing. always started in netural though, finally had to change it out.
Old Jun 20, 2012 | 08:49 PM
couperdecar's Avatar
couperdecar
After 35 years of starting that V8 , I'm sure its yor starter. I just went through an adventure of my own. Last year my starter was acting up, so I went looking for a mini. Local NAPA could bring a mini for $140. What a deal ! It got here and its Chinese made with an American name. Took a chance and put it in. This year the darn teeth on the mini got wiped out. Junk. I went to Napa to get a straight rebuild. And THAT one wouldn't work all the time. Took it back for warranty. Finally that one works. Working for 3 days now!
I looked on the net and couldn't find an American made mini starter. Anyone know who makes one?
