Any thoughts on the 1995 350 engine
Old Jun 20, 2012 | 02:28 PM
Camivette's Avatar
Camivette
Default Any thoughts on the 1995 350 engine
I know chevy called this a vortec but the "better" vortecs came out in 96. Will the accessories from my 78 bolt right on. And the big questions are will my intake work and does this year have roller lifters?
Thanks for the knowledge
Old Jun 20, 2012 | 04:37 PM
MelWff's Avatar
MelWff
the cutoff year for gen 1 is 1986, so you cannt put a 78 intake on a 95.
Old Jun 20, 2012 | 05:04 PM
bluedawg's Avatar
bluedawg
I have an lt1 in my 95 camaro, sweet ride for bone stock.
Old Jun 20, 2012 | 05:24 PM
Vette5.5's Avatar
Vette5.5
I also had a 96' Z28 with LT1 engine. While similar to Gen1 small bocks there were some differences. While not important here, the rear main seal mounted different. For accesory mounting consideration, the water pumps were driven off the cam, so no belt pulley. Also, reverse cooling was used, where coolant entered the heads first, so is upside down. While good engines, also had their share of strange leaks.
Old Jun 20, 2012 | 08:14 PM
Shark Racer's Avatar
Shark Racer
Not true on the cutoff. L98 heads will support early intake manifolds.
Old Jun 21, 2012 | 09:07 AM
Camivette's Avatar
Camivette
I'm gonna pass. $400 for a "fresh rebuild" seemed awful good but I'll stick with an earlier block I know or a later Vortec which has the better potential. Thanks
To Any thoughts on the 1995 350 engine
