New Car...First projects
Old May 25, 2002 | 05:42 PM
Double_0_7's Avatar
Double_0_7
Default New Car...First projects
First I have to fix the headlights. They light up, but won't open. I can probably find it, and the guy I bought it from gave me lots of parts, new and old, plus a haynes shop manual. But if you guys had anything off the top of your head, i would appreciate it.
The real thing I need some suggestions on is this: The brakes are super mushy. I have seen posts saying similar things. What should I replace, What should I have fixed elsewhere? I saved some money to get the car roadworthy, and that is really all it needs for right now.
Old May 25, 2002 | 06:08 PM
Pete Z's Avatar
Pete Z
Default Re: New Car...First projects (Double_0_7)
Since it's a 82,you are going to be a regular at this site too:
http://www.crossfire.webhop.net/
Everything Crossfire and more!
:cool:
Old May 25, 2002 | 07:53 PM
Double_0_7's Avatar
Double_0_7
Default Re: New Car...First projects (Pete Z)
actually he took off the crossfire and sold it. He put on a carb. I will probably go back to it one day, but for now, I need to worry about the big stuff for safety like the brakes. I think I have the headlights figured out, or at least enough to get started, but the brakes I haven't a clue.
Old May 25, 2002 | 08:00 PM
razz1980's Avatar
razz1980
the calipers on these vettes need the iron pistons replaced with stainless steel ones..the easiest way is to get pre-made new ones and u will get a credit back for ur old calipers..i replaced mine and its pretty straight forward..musken brakes,disk brakes are us,mid-america,ecklers,ect. any of these places have core exchange programs for u..
Old May 25, 2002 | 08:06 PM
Steve Grodin's Avatar
Steve Grodin
I would start with the simple fix and bleed them first. Before bleeding check the master cylinder and if the fluid dirty, suck it out first before adding new fresh fluid. :chevy
Old May 25, 2002 | 09:56 PM
A C's Avatar
A C
Cruise-In II Veteran
Default Re: New Car...First projects (Steve Grodin)
You may very well have a loss of vacuum, which would affect both your headlights not opening, and a loss of braking.
AC
Old May 25, 2002 | 10:53 PM
Jason628's Avatar
Jason628
Greetings,
I just went through the same thing on my new 74 project...After replacing vaccum lines and rebuilding the actuatators not only did the headlights work but the brakes improved dramatically! While I agree the brake upgrade is a great idea as well (I did that before the headlights and didn't notice any difference...but now there's a big difference!), if money is a concern, I'd start with the headlights and save up for new calipers.
Good luck!
Old May 25, 2002 | 11:56 PM
Double_0_7's Avatar
Double_0_7
Default Re: New Car...First projects (Jason628)
Thanks for all the suggestions guys. Coincidentally, the vacuum thing is what I thought the headlight problem was anyway. When I first posted I hadn't even checked it out. I started reading through the haynes manual i have, and saw that the headlights are vacuum controlled. When I took my friend for a ride around the block, i tried the lamps during the day, and noticed that they start opening and then close again. It reminded me of my hydraulic jack when the valve isn't completely closed, so i thought of the vacuum. I had no idea that the brake problem might be related. The guy i bought it from said that he bled the lines and checked the easy stuff, but still could not find the problem. Maybe that was why. I'm going to try your suggestions tonight or tomorrow. I'll post an update when I get done.
Old May 26, 2002 | 12:01 AM
A C's Avatar
A C
Well, there is a very large vacuum line going right to the brake booster. A real good investment for a first time C3 owner is a Sears Craftsman vacuum guage. :D
Half the car runs on vacuum! :crazy:
AC
Old May 26, 2002 | 12:02 AM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Spend time at http://www.corvettefaq.com You'll find the answers to ALL your questions.
:yesnod:
Old May 26, 2002 | 02:29 AM
Stevo81's Avatar
Stevo81
Might want to check for leaks around master cylinder and wheels. Also to test rotors for runout. Brake check and upgrade is always a good first step. There is a test strip available to test quality of brake fluid, I think. Stevo
To New Car...First projects
