Speedometer Conversion
Old Jun 24, 2012 | 10:26 PM
Electra225's Avatar
Electra225
Default Speedometer Conversion
I bought a good working 140mph speedometer out of a 1979 Corvette. I intend to replace the 85mph speedometer in my 81 Corvette. Will this conversion work? Do I need to change anything in the transmission? Thanks.
Old Jun 24, 2012 | 11:37 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Should work fine, except for the PITA labor involved. Converted my '78 140 to a 165 years ago without any calibration or mods necessary. FWIW, once you've changed the head I'd suggest you disclaim the odo reading's accuracy (on the title or bill of sale) should you ever sell the car.
Old Jun 25, 2012 | 07:52 AM
KenSny's Avatar
KenSny
I'll drop the question.
Could he change out the transmission gear to get accurate mileage?
Old Jun 25, 2012 | 11:39 AM
TheSkunkWorks
Assuming the existing one is reading correctly now, unlesss the new speedo is only a reface it should already be properly calibrated and give correct MPH without changing the transmission's speedo output gearing, which also means the odometer will accumulate mileage accurately too. It's the total mileage that will never be accurate without running it up to match what's already on the clock before installation.
Old Jun 25, 2012 | 12:30 PM
Electra225's Avatar
Electra225
Ok thanks! My old speedometer was broke and didn't function so the mileage was already off when I got the car. It has been through a substantial renovation since then. I took the 140mph speedometer apart and reset the odometer to zero. I plan to put the dash and gauges in the car next week.
Old Jun 25, 2012 | 12:55 PM
lionelhutz's Avatar
lionelhutz
It seems to me all GM mechanical speedos expect 1000 revolutions per mile or they'll read 60mph when the input is turning 1000rpm. So, it will be fine if nothing in the driveline or rear tire size changed. If you did change something, then use one of the online speedo gear selection tools.
Old Jun 25, 2012 | 04:32 PM
KenSny's Avatar
KenSny
Sorry, I stated my previous question wrong. I did not mean mileage I meant speed.
If I'm not mistaken on the older speedos you can remove the back and cover where the number rollers are and manually reset the numbers.
Old Jun 25, 2012 | 05:13 PM
TheSkunkWorks
FWIW, if your car has cruise control, could very well be the transducer went and in the process broke a cable, resulting in a non-functioning speedo. So, I'd check for that. And, I'd hang onto the old head in case having it on hand helps you sell down the road.
To Speedometer Conversion
