clock issue
Old Jun 25, 2012 | 08:08 PM
1977c3's Avatar
1977c3
Default clock issue
Took a little time to work on my 77 today, had to replace the temp gauge. well everything worked except for the temp gauge, now that i have it back in the car everything works except for the clock. it worked when I took it out now nothing. but if i pull out the **** and start the change the time the second hand starts moving and the clock works. as soon as I release the adjustment **** the clock stops. any idea whats going on here? i searched the web and around here on the forums and so far havent found an answer.
any ideas?
Old Jun 25, 2012 | 10:49 PM
1986coupe's Avatar
1986coupe
Perhaps when you are pulling on it you are making a better ground connection. Check the ground. If not then it may be something internal in the clock.
Old Jun 25, 2012 | 11:42 PM
Shark Racer's Avatar
Shark Racer
Did the clock work beforehand or has it always done this?
Old Jun 26, 2012 | 12:36 AM
1977c3's Avatar
1977c3
Its worked flawlessly since I have had the car. Was working when I took it out today to replace the temp gauge, reinstalled it 15 minutes later and now it only works when I try to change the time as soon as I release the **** it stops.
Old Jun 26, 2012 | 12:41 AM
Mashman's Avatar
Mashman
Was it in your garage? Is it dusty it here?
My guess is that when you removed it, it was exposed to dust in the air, and the dust has gunked up the works. So, im guessing it just needs a good cleaning.
Old Jun 26, 2012 | 12:51 AM
1977c3's Avatar
1977c3
possible, but not likely it was out of the car less than 15 minutes and the clock itself was never exposed to any dust or dirt.
Old Jun 26, 2012 | 07:08 AM
Roco71's Avatar
Roco71
Sometimes all they need is a little light oiling to get them going again. Worked on mine.
Old Jun 26, 2012 | 08:29 AM
BHRIG's Avatar
BHRIG
Make sure the contacts to the printed circuit are tight and nuts on with
open side down(raised ridges contact printed circuit)
If you have smooth side down , It might not break surface.
WD-40 lightly sprayed in hole in rear will lube works.......
Also, make sure the contacts in the plug for all the gauges in the center console are not folded or torn......
To clock issue
