Alternator problem
Old Jun 25, 2012 | 08:35 PM
lobo8152000's Avatar
lobo8152000
2nd Gear
Default Alternator problem
Hello, I have a 1980 vette, old alternator only putting out around 5-8 volts,bought new alt. and battery, new alt is not charging battery and new alt. reading 24 volts , what could be the issue here? thanks.
Old Jun 25, 2012 | 09:10 PM
brando1118's Avatar
brando1118
Bad voltage regulator?
Old Jun 25, 2012 | 10:37 PM
1986coupe's Avatar
1986coupe
Is that reading from the dash or from a multi-meter tested from the alternator or the battery?
Old Jun 26, 2012 | 12:45 PM
dsagers's Avatar
dsagers
First off, an alternator is a battery maintainer not a charger, if you have 5 to 8 volts you have a battery that needs to be charged, you have a bad battery, bad grounds, or high resistance in the positive cables. You must make sure the voltage is at 12.5 volts at the battery, the battery post in the alternator, and the starter post this should be done using different ground points to verify the grounds are good.
Excessively high voltage is a bad regulator, bad connection, bad battery, or a flying short in the rotor. If it is a cheap parts house rebuild it could be a regulator or rotor. A rotor will ohm test OK on the bench but when it is spinning at 2000 shaft RPM it can develop a short or excessive resistance which can drive the voltage up.
I bought a 200 amp unit for my 1981. Had to use a Buick alt case, was a special build. It's not listed on his web site, so you have to send him a message and ask for the details. Darren@rushps.com.
Cost was hefty, but I want something that will last forever, and 63 amps from the stock unit is a joke.
To Alternator problem
