Idler Pulley, 77 L82
Currently my baby is screaming at me when I go to fast and Im not talking my wife. That being said a few years back I removed the AC compressor as the AC didnt work and I prefer the windows down. I have moved countless times in the last seven years and have lost the compressor. So now, no compressor means to much torque and the belts squeel like a stuck big. When the compressor was on I didnt have this problem. So now Im stuck, I can either hunt for a used compressor just to run dumb on the bracket or is there anyone out there who have had this problem? Im thinking an idler pulley to fit on the bracket or another other way around this. Any help would be great. Thank you in advance.
You'd need to remove one of the pulleys to get the belt on, altho some guys say they've got the belt on by prying it over the edge of the pully and bumping the motor over. I'd remove the pulley, tho.
As to belt size, you'd need to figure it out yourself. The "book" size wouldn't work for you because you have AC pulleys, different diameters from non AC.
Do a search, this was discussed in detail a while back with some belt recommendations.
Here ya go...............
http://forums.corvetteforum.com/c3-t...lt-needed.html
Water pump pulley also tight?
Last year i also took the A/C off my 1970 SB. Owned the car over 20yrs, never had a squeel. Now i'm struggling with the same issue you are. I have verified that my belt alignment is good. i started to believe that the water pump pully on A/C cars is smaller than the nonA/C cars. A tech at Mid America told me the pulleys are the same size. So I have reverted to putting a belt between just the crank pulley and the water pump pulley. I'm not crazy about this idea because I have never seen a SBC run with this belt arrangement in all my years. Yet the AIMs manual does show this configuration but there is no explaination as to when and where it was applicable. I ran to the parts store about 5 times before I got a belt that would work with no idler. The belt I got can be massaged over the pulleys without loosening the fan pulley bolts. But I still think it is too tight. The belt I am using is a NAPA # 7350 or 7355, I don't remember which right now. I am going to try to go to a different brand to try to get a belt about 1/4 inch longer. BUT STILL i DON'T UNDERSTAND THIS. I DON'T BELIEVE A SMALL BLOCK CHEV SHOULD NEED THIS BELT UNLESS IT IS REWORKED SEVERLY FOR MUCH MORE TORQUE. Mine is just a 350/350, it does rev quickly but ...... I don't know, I'm still trying to figure it out. Dave.
Im going to get the alt/water pump pulleys blasted. If I could pull the PS and cranks I would do that.
Also, in hind site, I do recall that a non AC alt pulley belt is about a half inch shorter than what I have on my set up (stock).
Oh sigh. Dave Im going to give you idea a shot, though I also agree that it seems like a little much.
I have also tried tightening, loosening (resulted in high engine pressure spitting out coolant), emery cloth...
