74 speedometer gear question
Old Jun 26, 2012 | 08:18 PM
marc 1's Avatar
marc 1
1st Gear
Default 74 speedometer gear question
Working on a 74 with TH400 with 3.55 rear and stock tires. Which speedometer gear should be used with this combo?
Old Jun 27, 2012 | 09:33 AM
LastC3AZ's Avatar
LastC3AZ
this might help ..... without knowing what drive gear is in the tranny, its difficult to calculate .....
but check this ..... http://www.bgsoflex.com/speedo1.html
Old Jun 27, 2012 | 09:46 AM
gbvette62's Avatar
gbvette62
You need to know the final drive ratio and the tire diameter.
The 74 Assembly Manual has a chart in it (UPC 12J - Sheet 6), that lists all of the engine/trans/rear combinations, and the proper speedometer gear as installed at the factory.
As an example, from the chart a 74 Corvette with automatic, the 3:08.1 rear and standard GR70R15 tires (P225/70R15 in today's sizes); used a pink 35 tooth driven gear.
To 74 speedometer gear question
