78 fuel filter
Old Jun 27, 2012 | 07:15 PM
lonzoo's Avatar
lonzoo
Default 78 fuel filter
Anyone know if the fuel filter on a 78 has a check valve type ball. If so is it in the filter? Took mine out and all there is is a spring and the filter. How does it stop flow back to the pump? Any help would be appreciated.
thanks, Lonzoo
Old Jun 28, 2012 | 10:53 AM
MelWff's Avatar
MelWff
It should be part of the filter which you should see when looking in one of the ends. If not there somebody put the wrong filter in. This link gives you the correct NAPA part number.
http://forums.corvetteforum.com/c3-t...rain-back.html
Old Jun 28, 2012 | 02:09 PM
lonzoo's Avatar
lonzoo
Thanks MelWff.
After reading your response I went to NAPA and bought the filter. Just like you said, mine was messed with. The new one has a check ball inside the filter....mine did not. Thanks for the great info.
Lonzoo
To 78 fuel filter
