Vortec vs. ProComp
http://www.stevesnovasite.com/forums...d.php?t=161866
GM in the 1950s had 55 percent of the world car market. Lets think about that besides ford and chrysler think about all the car brands all over the world at that time. There arrogance of lets build the same old cheap crap the suckers will keep buying our cars did not work out for them . They went from 55 percent of the world market to a small market share to bankruptcy with this arrogant attitude. The new 69 Z/28 i mentioned it had no damage from shipment to the dealer. The dealer had to put it in there body shop shoot more paint on the roof easly done with laquar paint. Reason you could see primer the paint was so thin. I ordered a new 78 vette it came in on the left rear quarter panel primer was completely showing through about a foot long ray charlse could spot it from 20 ft, no problem ship it to the dealer. The new 79 Z/28 i ordered came in it was a white car. The doors fenders hood did not match the color of the body. GM had got the brillant idea to save time of painting parts seperately. That did not work anybody with any eyes could easaly see it. No problem get it the dealer screw the customer we have 50 percent plus of the world market the suckers will keep coming in. Don't get me started on the new 1978 3/4ton chevy silevrado pickup i bought. I bought five new chevys from 1969 to 1979 three of them the dealer had to repaint. Everytime i think of the 78 pickup i paid good money for i would like to take a baseball bat to the gm brass of that time period. Even the right had passenger door hinge you know the door far less used the hinge broke loose from the door. GM in that time period had good body stylest in the 50s, 60s thats all they had.
I have never bought a GM product since 1979 never will again. Would i buy an older chevy based on its styling just liking the car yes. For new car transportation there will never be a gm car in my driveway ever again. Have never owned a foriegn car but many japanese motorcycles. GM will never get another dollar off this ole boy again.
Dart shp 200
http://www.summitracing.com/search/D.../?autoview=SKU
I do agree that the Vortec heads are a good option if the OP wants to do a budget build since he already owns them.
I have yet to have a pressed-in oil pump pickup come out. The ones I've seen that have were either a used pickup in a new pump, or were driven in with a chunk of wood or a screwdriver. Using the right tool with a little Loctite sleeve retainer works fine. Certainly if someone's going racing a retainer or a braize zot isn't a bad idea...but it's not required for a street engine...but can certainly be done if someone worries about such things. Again, good engineering that serves very well in most cases. Stuff happens, but the failure rate is exceptionally low.
The Vortec debate apparently soldiers on and edits abound
As I've said, for the OP the expense of having a good valve job done vs. the cost of a new set of heads makes the Vortecs a great choice if his power targets are around 1 HP/CID or a little better. There's no reason to monkey around with them and add cost - just run 'em. Additional flow with additional port cross-section is a trade-off to some extent. Buying moar head for moar power is of course fine - but a blanket recommendation without understanding what the power targets are makes no sense to me...and double-check anyone's math on the true and full cost of "moar". Many good choices...that all stem from a good design and budget
Keep the shiny side up!
Scott
As I've said, for the OP the expense of having a good valve job done vs. the cost of a new set of heads makes the Vortecs a great choice if his power targets are around 1 HP/CID or a little better. There's no reason to monkey around with them and add cost - just run 'em. Additional flow with additional port cross-section is a trade-off to some extent. Buying moar head for moar power is of course fine - but a blanket recommendation without understanding what the power targets are makes no sense to me. Many good choices...that all stem from a good design and budget
My 73 LS4 when i pulled the pan low and behold the pickup tube was brazed to the pump.
Vortec heads best attribute is its combustion chamber its runners nothing special. if you take them put screw in studs in then durabity is good as any then. Thats why chevy did it to there 180 runner over the counter head. The ball stud system is cheap junk nuts always backing off them always had problems factory shaft sytems never had.
I had a brand new car pulled back with a wrecker to cliff peck chevy where i bought it with 18,000 miles on it. They put a new crank two new rods in under warranty because of chevys pressed in pick up tube. My grandfather did not tell me his milage only the engine was replaced under warranty pickup tube feel out of the pump.
http://www.stevesnovasite.com/forums...3&d=1287543966
The thing is his desktop dyno numbers show 437 hp @ 6000 RPM. With nothing but a change to AFR heads he would be over 500 hp with this combo with exact same specs and better power throughout the entire operating range of the cam.
http://www.stevesnovasite.com/forums...4&d=1287544308
namecalling deleted- let's end that here...
The Forum should be a place where we treat one another with civility so that it remains a fun and friendly place to hang around with other Corvette enthusiasts. Hostility to others is rude and inappropriate.
Personal attacks cannot be tolerated. Attack ideas, not fellow Forum members.
http://forums.corvetteforum.com/foru...rd-others.html
Scott
Again, the namecalling ends here.
Last edited by vettebuyer6369; Jul 2, 2012 at 11:47 PM. Reason: namecalling, hostility
they have been great heads for me.... And Valley heads says the World heads are build well. Gkull also uses Valley Heads for there race cars.. but he did state something to the fact that after Valley Heads are done with them, they are no longer really Sportsean II heads... fwiw.... p:-)
and I would like to say also, little mouse and 68mako really helped me out with the valve train... put me in a great direction... that valve train runs like a bat out of hell because of them.
I think LM is just kidding here........sarcasm at best.
He is nowhere close to being a troll.
Look up his other posts - its easy just click on his profile.
He gives out a lot of good info.
Peace
Bman
Chevys short blocks are great always had a good oiling system where olds and buick of that time period did not. There heads well the stud system is not the way to do it very cheap in cost to make always been the source of chevy problems. The bronze valve giude was created to fix the SBC bad valve guide problems other companyies did not seem to have. BBC had removable valve guides. I worked in a machine shop on heads seen all brands come through, i was a chevy brand loyalist at that time. The SBC head was the pitts thats the truth no sugar coating, no political correctness.
Pressed in studs are junk looking for a reason to fail. Screw in studs better of a bad design. You can put a patch on it with a girdle or get rid of the crap with aftermarket shaft system.
When i had a BBC one of my friends refered to big blocks as " weak as wet toilet paper " he liked lunati cams at the time i refered to his cam as lunatic cams. i was running cranes he refered to my cam as crap cams. Over on the cafe racer forum i'm on where i go by JM360 under it as my favoite saying is " WEAK AS WET TOILET PAPER " do i believe that no, but i love the saying lol.
If i put " weak as wet toilet paper " under little mouse, SBC folks might get excited and offended. lol.
The designer of the lunati voodo is very good a well known fact. I have come on this forum many times directing someone to it. Not knowing them did i come on and say, gee why don't you get one of those LUNATIC cams.
I have tought that if i could get a reverse rotation cam made up for a SBC shrink it only slightly in size. It would make a very good starter motor for a BBC.
