'77 Starter
Old Jun 28, 2012 | 11:39 AM
Red 77L48's Avatar
Red 77L48
Cruising
Default '77 Starter
My 77 will not turn over when she's hot and most folks I talk to say it's the starter. So, this weekend I'm going to dive in a do it.
Looks like a pretty straight forward job. Anything I should be aware of that I'm NOT aware of now?
Thanks for any and all input!
Old Jun 28, 2012 | 12:08 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
The first thing I'd do is make sure the battery is good. It's not fun buying and replacing a part only to later find out something else is at fault.
Old Jun 28, 2012 | 12:13 PM
MelWff's Avatar
MelWff
what temperature thermostat do you have? Did you check all battery cable connections including the ground under the battery box?
Old Jun 28, 2012 | 12:22 PM
bluedawg's Avatar
bluedawg
You probably know this, but before you dive into the starter disconnect the positive battery cable.
Old Jun 28, 2012 | 10:38 PM
oldalaskaman's Avatar
oldalaskaman
you are to late for the cheap fixes for heat soak, but they may work, heat shield , remote starter solenoid, etc. If you install a new or rebuilt starter and at the same time do the cheap heat soak fixes , it will last longer. hope this helps
To '77 Starter
