I recently picked up a used 383 SBC which I was told had a weight welded onto the crank which would allow me to re-use the flywheel off of my 327. Please see the attached pictures of the weight welded on the rear end of the crank.
Knowing that my 327 is internally balanced and uses neutral balanced flywheel, and the 383 is an externally balanced engine which normally uses a weighted flywheel I'm hoping for some re-assurance on this before swapping motors.
The research I've done hasn't mentioned this as a method for balancing an externally balanced engine.
I'm hoping someone recognizes this method of balancing an externally balanced crank so that it can use a neutrally balanced flywheel from a 327 or 350 SBC instead of what is typically used (a weighted flywheel for a 400 crank).
Let me know if this looks familiar.
Yeah I hear ya, but I'm not seeing any evidence of the internally installed weights (which I believe are usually drilled and recessed into the crank counterweights) so I'm thinking its externally balanced.
It does have the 400 style dampener on the front.
It looks like a fair amount of weight. It is added to the external portion of the crank. It's in the same location as a weight plate that lets you use an internal balance flywheel or flex plate on an external balanced engine.
Never seen that way of balancing.
Looks like someone put some effort into it though.
Yes, with the weight it looks like it is what I was told it should be (ready to use a neutrally balanced flywheel) but I'm hoping that I can get some feedback to assure me that this method of balancing a 383 will do that.
only a balance shop can confirm that crank is IB, If you ask me........... It is a bubba cast 400 crank that somebody ground the journals to 350 main size and welded some weight to for what ever reason
I was hoping somebody would recognize this as an acceptable method of balancing a 383 but I'm starting to think it might be best to take the engine to a balancing shop to have it confirmed.
[QUOTE=gkull;1581198370]only a balance shop can confirm that crank is IB, If you ask me........... cast 400 crank that somebody ground the journals to 350 main size and welded some weight to
It's like the weight plate, and the guy had some welding skills, however I would be skeptical of higher rpms.
To answer your question, I've never seen it done that way before. Would it be my idea of the way to do it? No, not really. Will it work? It may, probably be hard to find someone to guarantee it.
Normally balancing of cast crank shafts is accomplished by adding heavy mallory metal to the crank throws. Bubba in this case cut up another crank shaft and welded the throw to the end of this stroker crank. Is it truly balanced................. Or did it also require a damper of equal weight as a matched set.
Would I use it ................ NO! When new internally balanced cranks are so cheap.
Looks like I'll be taking it to an engine balancer to get it checked out and done right then.
Anybody have any recommendations for the Portland OR. areas?
