1980 Smoking when decelerating
Old Jul 1, 2012 | 11:36 AM
tyler77's Avatar
tyler77
Default 1980 Smoking when decelerating
Any Ideas?
I have a 1980 that runs great, but is smonking when I decelerate or take my foot off the gas. This is what I have checked or done.
1. I changed the valve stem seals.
2. Checked the intake, carb, & distributor by spraying starter fluid around all the gaskets at idol. No increase inceleration.
3. Put in a new pcv valve and checked all vacuume line for oil, all clean and dry.
4. Pulled spark plugs to see if they were foul-up no signs of oil all look good. Thought it might be a oil seal or piston ring.
Any other idsas? I'm thinking leak down test just to know.
I would appreciate any help or ideas you might have.
Old Jul 1, 2012 | 12:04 PM
Michael MacPherson's Avatar
Michael MacPherson
When an engine smokes during decel only it is usally valve guide seals. Did u replace the exhaust seals as well. And are they properly seated. The excess vacume created during decel is what sucks in the oil.
1 check the oil return ports inside the heads. make sure oil isn't pooling up on top of the heads
2 while in there make sure valve seals are properly seated intake and exhaust.
3 clan the pvc valve and hose and port at intake, make sure there are no restrictions
4 clean the fresh air port on the other valve cover, make sure no restriction.
5 test, check for smoke during decel, if engine still smokes, broken ring most problebly.
MIKE
Old Jul 1, 2012 | 01:41 PM
DRIVESHAFT's Avatar
DRIVESHAFT
If its an automatic trans car, check for a leaking vacuum modulator.
Old Jul 2, 2012 | 02:53 PM
hugie82's Avatar
hugie82
Old Jul 2, 2012 | 03:06 PM
Big2Bird's Avatar
Big2Bird
If the smoke is white, yes, if blue, no.
Old Jul 2, 2012 | 07:57 PM
Tim81's Avatar
Tim81
Could be worn valve guides and the new seals can't help it. What type of seals did you use?
Old Jul 4, 2012 | 11:28 AM
tyler77's Avatar
tyler77
These are what I used - Fel-Pro QSS72861 - Fel-Pro Valve Stem Seals
Valve Stem Seals, Viton®, Positive Stop, 11/32 in. Valve Stem, Set of 16
07-02-2012 05:57 PM
Old Jul 4, 2012 | 11:33 AM
tyler77's Avatar
tyler77
It's a manual 4 speed, only has 40,000 miles on it but it is 32 years old.
Old Jul 4, 2012 | 03:36 PM
Tim81's Avatar
Tim81
Do the valve seals fit tight on the guide boss. If they don't then they could act like a pump when the engine is running and pump oil into the guide. I'm assuming your heads are 624's with no mods. Can you tell us what color the smoke is?
Tim
Old Jul 4, 2012 | 05:44 PM
tyler77's Avatar
tyler77
Tim
Tim the smoke is white and valve stim seals pushed down on the stims very tight. I have not lost any antifreeze so I can't be burnning it up, it's got to be oil.
Old Jul 4, 2012 | 05:51 PM
Tim81's Avatar
Tim81
White smoke sounds like trans fluid is burning. My Bad you said it was a 4 speed.....
Tim
Old Jul 4, 2012 | 07:30 PM
...Roger...'s Avatar
...Roger...
You might be sucking in some coolant.
Old Jul 4, 2012 | 11:20 PM
tyler77's Avatar
tyler77
Roger my coolant level has not droped at all.
Old Jul 5, 2012 | 07:09 AM
...Roger...
It doesn't take much to create steam,does the smoke or steam dissipate quickly ?
Have you noticed your engine oil level dropping ?
Old Jul 5, 2012 | 06:05 PM
tyler77's Avatar
tyler77
Yes, but that's not unusual. I have had an oil leak for a while, before the smoking started.
Old Jul 6, 2012 | 07:47 AM
Tim81's Avatar
Tim81
Here is some food for thought, it may be a intake manifold gasket or head gasket leaking.... Tim
To 1980 Smoking when decelerating
