How many flywheel teeth does a 68 have?
Old Jul 2, 2012 | 08:11 AM
avner's Avatar
avner
Default How many flywheel teeth does a 68 have?
Hello
How many flywheel teeth does a 68 have with 327 / 4 speed?
Avner
Old Jul 2, 2012 | 08:25 AM
gkull's Avatar
gkull
Originally Posted by avner
Hello
Avner
Look at how the starter is mounted. Small diameter fly or flex has 153 larger is 168
Old Jul 2, 2012 | 08:26 AM
speedreed8's Avatar
speedreed8
since its a 327 i would say that its a 10.5" clutch setup that uses the 153 tooth flywheel
Old Jul 2, 2012 | 08:37 AM
avner's Avatar
avner
I thought 153 fly wheel for 4 speed and 168 flexplat for auto trns'
Am I correct or there are more parameters to define the teeth#?
Avner
Old Jul 2, 2012 | 08:40 AM
avner's Avatar
avner
What you mean by "Look at how the starter is mounted"?
It have 2 bolts
Old Jul 2, 2012 | 09:38 AM
Garys 68's Avatar
Garys 68
The bell housing of a 153 tooth has sort of a squared off corner the starter mounts in. The 168 tooth (621) bell housing has more of a rounded bulge. Look at a few GM bell housings on ebay, youo'll see what I mean.
Btw, my 68 small block 4 speed had a 153 tooth.
Old Jul 2, 2012 | 09:55 AM
gkull's Avatar
gkull
http://www.chevytalk.org/fusionbb/sh...hp?tid/171683/
Old Jul 2, 2012 | 11:49 AM
avner's Avatar
avner
I will check the bolt position and see what I have.
Thanks for the replies.
Avner
To How many flywheel teeth does a 68 have?
