1982 ECM connectors - removal
Old Jul 2, 2012 | 09:31 AM
SG82's Avatar
SG82
Cruising
Default 1982 ECM connectors - removal
Can anyone help
I have an 82 and want to remove the ECM. What I cannot figure out is how the connectors release from the ECM. There seems to be a small tag on one side of each connector, and it looks like you need to squeeze these inwards and then pull the connector out. However I have tried this gently, as I do not want to break anything, but the connectors do not release. Am I missing something?
regards from the UK
Old Jul 2, 2012 | 05:34 PM
1yy07's Avatar
1yy07
Default 82 ecm
you have to pull up the carpet be hind the drivers seat 1st. then take out battery.
Old Jul 2, 2012 | 05:46 PM
LastC3AZ's Avatar
LastC3AZ
It is difficult to get the connectors off if they've not been pulled before ..... the clip you describe is the only one .... and its just a matter of wiggle and pull ... they will come off ...
Old Jul 4, 2012 | 03:27 AM
SG82's Avatar
SG82
Cruising
HAl1PHX
Thank you for your reply. The connectors are a very tight fit. Do I just need to squeeze the tab inwards then pull on the connector?
To 1982 ECM connectors - removal
