Bleeding Brakes
Old Jul 4, 2012 | 05:46 PM
jordan89's Avatar
jordan89
Default Bleeding Brakes
Happy fourth of July guys. I'm about to bleed my brakes with the Power Bleeder and wanted to know how much pressure is safe for when I start pumping this thing?
Old Jul 4, 2012 | 05:58 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
There should be directions with the product but I think around 15-20 psi. They work great btw, in case you haven't used one.
Old Jul 4, 2012 | 05:59 PM
Jud Chapin's Avatar
Jud Chapin
Here's Motif instructions...
http://www.motiveproducts.com/frame-instruct.htm
Old Jul 4, 2012 | 07:28 PM
Jeff_Keryk's Avatar
Jeff_Keryk
I use low pressure, like 10 psi. Someone told me high pressure can make air bubbles into a bazillion tiny bubbles. I just go around twice and tap on each caliper. Easy money.
Old Jul 4, 2012 | 07:37 PM
jordan89's Avatar
jordan89
Thank you guys for all the help. This is my first time using one of these. I think I'll keep it at around 10 psi as well.
Old Jul 4, 2012 | 07:41 PM
jordan89's Avatar
jordan89
One more brake related question, what are the torque specs for the caliper halfs, front and rear? I'm putting these things together right now and need this info asap.
Old Jul 4, 2012 | 07:49 PM
Mooser's Avatar
Mooser
Van steel lists the caliper housing bolts as
front 130 (13/16)
rear 60 (5/8)
Caliper mounting bolts
Front/rear 70 (5/8)
HIH
Mooser
Haynes manual says the same
Old Jul 4, 2012 | 07:52 PM
dariopop's Avatar
dariopop
caliper mounting bolt front---70 ft-lbs
caliper mounting bolt rear----70 ft-lbs
caliper housing bolts front----130 ft-lbs
caliper housing bolts rear-----60 ft-lbs
Old Jul 5, 2012 | 11:01 AM
TWINRAY's Avatar
TWINRAY
Verify it's not leaking around the cap before you start the process.
Old Jul 5, 2012 | 11:10 AM
jordan89's Avatar
jordan89
How would I do that?
Old Jul 5, 2012 | 11:23 AM
TWINRAY's Avatar
TWINRAY
With my Motive bleeder, I've had instances whereby I thought I had the cap of the bleeder fastened correctly to the top of the Master cylinder - yet when I started pumping the bleeder, brake fluid was leaking from the master and the lid. just saying, make sure your lid connection is secure before you start walking around the car to bleed it and then find (later) you've lost a quart of fluid from it leaking out.
Old Jul 5, 2012 | 11:31 AM
jordan89's Avatar
jordan89
I have read about sealing issues with this bleeder and our master cylinders. I think i remember people using a block of wood and, i think C- clamps, to get a tight seal?
Old Jul 5, 2012 | 11:41 AM
TWINRAY's Avatar
TWINRAY
That's what I use too - still have to make sure you don't get a leak. I saw somewhere else, a Motive bleeder with a aluminum top plate. Mine has a plastic plate with a rubber gasket seal - which the last time I used it, has become "unglued" from the plate and now has to be carefully positioned but with brake fluid, tends to become slippery. I actually had better luck with a manual bleed than with the Motive in getting bubbles out on my '69.
Old Jul 5, 2012 | 12:33 PM
Mooser's Avatar
Mooser
I use one "quikgrip" type clamp
I also don't put any fluid in the container, just use the air pressure and need to remember to check the level in the reservoir. Somehow seemed better then ending up with a bunch of fluid in the pump and having to deal with that.
Done that way for a couple of years, zero-problems so far
Mooser
Old Jul 5, 2012 | 09:37 PM
dariopop's Avatar
dariopop
Pump it up to 10lbs dry 1st, if it holds than release the pressure and add brake fluid to the container.
Old Jul 8, 2012 | 01:43 AM
jordan89's Avatar
jordan89
All great tips guys. Thank you all.
Old Jul 8, 2012 | 10:42 AM
richardttu's Avatar
richardttu
I used mine for the first time yesterday myself. I did have a little trouble with leaking from the Master. But I used a quick clamp like Mooser did (I have the metal plate version) and no further problems. I bled at 10-15 lbs. Next time, I will not even use the bolts that came with the bleeder, just the clamp.
To Bleeding Brakes
