Cost involved with switch to offset trailing arms ?
Gentlemen, I've learned a huge amount here from your posts. Can you suggest what it would cost (ball park figures ) to switch from stock to aftermarket offset trailing arms on my rusty old 1980 C3 ? What about if the custom vette shops do it for you ?
The bare arms are about $1000, then you have to disassemble the parts off the old ones to switch over and install and align. I wouldnt be surprised if the whole job comes to $3,000. Why do you want to do this?
If your arms are rusty and old you are best going in and replacing all the bearings. If you do that you are looking at about 450-500 for a pair of trailing arms and around 250-300 for a rebuild kit for both sides. Additionally, if you do not have the tools add in another 200 or so for tools. You are looking at around 750-1000 if you do it yourself and probably more than that if you take it to a shop.
I've been researching this also, this post is pretty accurate
Looking into replacing T-arms also.If you factor in everything including an upgraded suspension,may as well spring for the VanSteel coil-overs.New offset T-arms adjustable coilovers for 2600.00.Good reviews on this setup.http://www.vansteel.com/index.cfm?fu...&SubGroup=1971
For the cost of the offset arms, he could install a nice set of 18" wheels and have no clearance issues. Just saying...we don't need the cost of offset arms to fit wide rims anymore. Offset arms were designed back when all that was available were 15" rims and tires.
excellent tech. I didnt know that, many thanks, bob
I just got done rebuilding mine, and did it myself. I went with the offset arms, but mainly because they are built so much stronger than the stock arms.
The hardest part about doing off set T/As is stopping with just the arms.
I went with the Van Steel offset arms and added... QA1 coilovers, Wilwood 4 piston 13" big brake kit, Tom's axles, Tom's camber control rods, Van Steel shortened sway bar, 3 1/2" half shafts, a Gary Ramedi 12-Bolt rear end with 3.73 gears, 18" wheels, Nitto 285/40ZR18 drag radials...
Oh and don't forget if you do all of this in back then you HAVE to do the front...
Thank you once again for all of your input regarding the trailing arms.
Gentlemen, all you have given me much to think about and to research. You are generous in sharing your knowledge and experience with those of us who are new to these wonderful cars.
So are u guys saying I can run a 10' wheel if I go to 17 or 18" wheel with the stock trailing arm?? Increasing the back spacing 2" over stock? I thought you guys were crazy, but looking at the angle of the stock trailing arm I can see a bit fo increase in backspacing there if the wheel diameter increases.
This estimate is "spot on." I did it myself about a year ago. Only difference is I happened to catch a Vansteel sale and picked up the T/A's for about $360.00. Picked up the tools from Mid-America.
