Vacuum question for 76 C3
Old Jul 7, 2012 | 09:14 AM
Iggycat2009's Avatar
Iggycat2009
Default Vacuum question for 76 C3
Almost there! Getting ready for first time start up after two years of rebuilding this car front nose to rear..
I removed the entire AC system due to the the previous owner removing most everything anyway. Installed an AC delete cover and painted to match the engine bay which looks good. I have a question on two vacuum hoses that penetrate the passenger side firewall.
According to the assembly manual here are the two hoses;
1) To Vacuum source (black hose, no stripe)
2) OA Valve (this has a green stripe on the hose and a grommet on the end)
I traced them back to the console controller and not sure if I should plug them or provide the vacuum. I don't think the OA Valve is operational any longer w/o AC - correct me if I'm wrong. Not sure what the other vacuum line is for. Thoughts?
Thank you,
Mike
Old Jul 7, 2012 | 12:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
OA is outside air. It was used by the factory AC and would have been used by regular fresh air system. Do you have a fresh air system with the AC removed?
Old Jul 7, 2012 | 12:56 PM
oldalaskaman's Avatar
oldalaskaman
just plug them, I think one was the vacuum feed for the system, without the system , you probably dont need them.... maybe
To Vacuum question for 76 C3
