Oil Pump Pick-up
Old May 27, 2002 | 09:08 AM
Ybnormal's Avatar
Ybnormal
Default Oil Pump Pick-up
When installing a new oil pump on an 81 S/B, how low in the pan should the pick-up be. I have the pump ready to go on but wanted to get some advice from someone who has knowledge of this procedure before I reinstall it. Thanks in advance guys, don't think I could do this without you all.
YBnormal..Drive a Vette, well at least work on it when you can't drive it.
Old May 27, 2002 | 09:59 AM
tworottiedogs's Avatar
tworottiedogs
Default Re: Oil Pump Pick-up (Ybnormal)
This isn't the way I did it so mine is probally off a little but the old timers at work gave me these instructions. Install the pump and insert the pickup but not too tight and hanging down too low. Install the pan slowly so that it pushes the oil pickup up. Remove the pan and raise the pickup another 1/4 inch and tap/braze or locktite in place. Reinstall pan. I kind of did it this way but I didn't measure the 1/4 inch. I just moved it a little. You don't want to be sucking the scum off of the bottom of the pan.
Old May 27, 2002 | 12:25 PM
Scott78's Avatar
Scott78
Default Re: Oil Pump Pick-up (tworottiedogs)
Just what 2rottiedogs said, about 1/4 to 3/8ths off the bottom is what I've always heard is the recommended.
Scott
To Oil Pump Pick-up
