Whats in your Suitcase
Old Jul 8, 2012 | 04:01 PM
8valve's Avatar
8valve
Default Whats in your Suitcase
I bought a 80 as a donor for the frame and engine for my 73 Coupe. I dont use AC and plan to do a complete AC Delete when I assemble my 73. I wanted to see what
the design was inside the suitcase so I could plan my AC delete. I need heat in the early spring and fall, other than that my roofs are off.
When I opened the suit case, look at all the leafs, pine needles and junk that was packed inside. Without question the AC was not cooling the cabin well, if at all.
The plastic mesh screens dont fit tightly and have to large openings. I will fab a well fitting screen frame and use fiberglass screen material so it dont not rust on my 73.
So if your AC passes all tests that its working, but still does not cool the cabin well..............Whats in your Suitcase.
8Valve
Old Jul 9, 2012 | 07:09 AM
Jedi926's Avatar
Jedi926
Wow!
Old Jul 9, 2012 | 08:05 AM
John 65's Avatar
John 65
I am building a 77 big block and want all the room I can spare under the hood. The non working heavy AC components were the first in line to go. I glassed the opening to the correct size and put in a small heater box from a non ac car, which works out just fine for me.
Old Jul 9, 2012 | 08:14 AM
8valve's Avatar
8valve
John;
When you put the heater box in the opening and closed it. Was the closure absolutely flat with the surface ?
8Valve
Old Jul 9, 2012 | 11:36 AM
jcloving's Avatar
jcloving
Very common to have that much stuff in there. I had pine needles, leaves, oak tree tassles, lot of pollen and dust.
I improved the fit of my plastic screns and added the foam filters from Ecklers. Plus, I never park under trees. It should never be a problem again.
To Whats in your Suitcase
