Clutch ball stud - which one?
Old Jul 9, 2012 | 05:09 PM
spf72's Avatar
spf72
Default Clutch ball stud - which one?
I am replacing my clutch and the ball stud in the bell housing is worn so I bought a new one. The new one is longer then the old one. Normally I would have thought that I bought the wrong part but I also noticed that Bubba has welded on an extension to the clutch adjustment rod. I am now wondering if the longer rod is needed as the ball stud was to short? Which one is correct? It is a 70 small block
Old Jul 9, 2012 | 05:16 PM
MelWff's Avatar
MelWff
stock appears to be 1 1/2"
http://www.ecklerscorvette.com/corve...1957-1981.html
Old Jul 9, 2012 | 05:44 PM
spf72's Avatar
spf72
Thanks, the new longer one is 1.5". I bought it from Paragon and they say it should be right but to match it up to what you have. The issue is that I think what I have may be wrong. I have done a google search and looked in a dozen books I have but can find nothing definitive.
Old Jul 9, 2012 | 07:35 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Suspect that should you use the longer ball stud you'll no longer require the bubba'd rod extension.
To Clutch ball stud - which one?
