1970 Rear Clicking
Old Jul 10, 2012 | 05:34 PM
Brcmpbl's Avatar
Brcmpbl
Default 1970 Rear Clicking
Hi guys. My 1970 has a persistent clicking noise in the rear end while driving. It is very steady and increases in speed with the speed of the car. I don't know if it does it in reverse. Sounds like there's a rock in the tires kind of, you know? I had a similar problem with a 77 I used to have and it was a bad u-joint...but I had 70 on a hoist today and all the u-joints are rock solid, no play whatsoever, and greased where applicable. Thoughts?
Old Jul 10, 2012 | 06:27 PM
...Roger...'s Avatar
...Roger...
If you have rallys , remove the beauty rings and drive. Its not uncommon for them to click,if they do grease the 4 retainer clips.
Otherwise you might look at the parking brake.
Old Jul 10, 2012 | 11:37 PM
1986coupe's Avatar
1986coupe
Another thing to check is to make sure the French locks on the back of the wheels aren't making contact with anything as the wheels spins. I have seen this.
Old Jul 11, 2012 | 01:48 AM
Brcmpbl's Avatar
Brcmpbl
Absolutely have rally wheels and absolutely the rings were clicking! Popped them off and went for a drive tonight and no noise (instant happiness), so I used the only lube I had on hand...venerable WD-40...back on, no clicking! I'll get some better grease tomorrow. This made my day, I was perplexed. Thank you.
To 1970 Rear Clicking
