Anyone running a CHAIN-LESS gear drive?
Old May 27, 2002 | 04:36 PM
Corey_68's Avatar
Corey_68
Default Anyone running a CHAIN-LESS gear drive?
I need to buy a timing gear and chain for the BB. I was thinking about a double roller, but thought to maybe run a Acu-drive system. Anyone running one? Is it good to 7,000rpms? Here's a pic.
Old May 27, 2002 | 08:30 PM
Stingy74's Avatar
Stingy74
Default Re: Anyone running a CHAIN-LESS gear drive? (Corey 68)
They have their purpose which is to have extremely accurate cam timing but the whine they produce get's tiresome just like running open headers.
Old May 27, 2002 | 08:43 PM
devveldogg's Avatar
devveldogg
I agree. I bought the "noisey "one and it is really getting on my nerves. first chance I get its coming out. Never taken mine to 7000 so don't know about that . :chevy
Old May 28, 2002 | 06:07 AM
Kevin Mason's Avatar
Kevin Mason
Not to mention the gear drive transmits vibrations from the crank to your valvetrain, making your valves cavitate and do weird things.
Old May 28, 2002 | 09:05 AM
73-454's Avatar
73-454
Default Re: Anyone running a CHAIN-LESS gear drive? (Kevin Mason)
Why, GM built 50 million V8's and the chains work perfect. So why mess with success
Old May 28, 2002 | 09:13 AM
norvalwilhelm's Avatar
norvalwilhelm
I ran a peter Jackson gear drive , the noisy one and it does get on your nerves but I am old and things like noise bother me. Funny I'm also deaf but I can hear annoying rattles. :)
Old May 28, 2002 | 10:59 AM
Corey_68's Avatar
Corey_68
Default Re: Anyone running a CHAIN-LESS gear drive? (norvalwilhelm)
Thanks for the info guys, I decided to go with the double roller for 1/3 the price.
:cheers:
Old May 28, 2002 | 11:58 AM
MikeC's Avatar
MikeC
I don't understand makes your valves cavitate, could you please explain what you mean?
Old May 28, 2002 | 12:17 PM
Kevin Mason
Default Re: Anyone running a CHAIN-LESS gear drive? (MikeC)
As I understand it, the valvetrain, springs and all, will vobrate in sympathy witht he vibrations transmitted from the crank.
This can lead to things such as valve float at certain enharmonic RPMs andincreased wear on valvetrain components.
Someone know knows this subject better than I can chime in now.
Old May 28, 2002 | 06:34 PM
Pete79L82's Avatar
Pete79L82
A geardrive will transmit harmonics from the crank to the valvetrain. This will cause flucuations in the timing at certain RPM's. It won't affect the springs or the valve or cause the valves to float. Engines that use a non-dampened gear drive will on occasion show more wear in the pushrod tips. None of these situations are a enough to cause problems on a street motor. Unless you need a gear drive (roller cam with very stiff spings) you are better off with a double roller chain or a belt drive. Unless you really like the noise.
Old May 28, 2002 | 07:22 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: Anyone running a CHAIN-LESS gear drive? (Pete79L82)
And I do :yesnod: :cheers:
Old May 28, 2002 | 08:02 PM
Maurice's Avatar
Maurice
I have the Pete J. loud roller, at first I loved it, then it got old, now I don't notice it after about 1 year.
Old May 28, 2002 | 09:17 PM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: Anyone running a CHAIN-LESS gear drive? (Maurice)
I like mine I usualy get two comments.
Do you have a blower under that hood!
or
I think your power stearing is going out. :rolleyes:
Old May 28, 2002 | 09:36 PM
Fevre's Avatar
Fevre
If you want blower whine, buy a blower. :yesnod:
Old May 28, 2002 | 09:57 PM
PrarieShark
Default Re: Anyone running a CHAIN-LESS gear drive? (Fevre)
Sorry Fevre but a blower is not somthing I want sticking out of my hood and its not in my budget. :)
Old May 28, 2002 | 10:47 PM
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
Default Re: Anyone running a CHAIN-LESS gear drive? (Wightnite)
:seeya I am running a Pete Jackson (noisy) gear drive I can't even hear it most of the time :D The car runs great! :yesnod:
Old May 28, 2002 | 11:21 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Re: Anyone running a CHAIN-LESS gear drive? (Intimidator454)
My girlfriend and I went to our local car show and a Chevelle went by with gear drive and she chimed up " I think he's low on oil!!" :rolleyes: :lol: :lol:
Old May 28, 2002 | 11:32 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Anyone running a CHAIN-LESS gear drive? (73-454)
I would never consider one of them gear drives!!
:cheers:
Olivier
Old May 28, 2002 | 11:49 PM
gkull's Avatar
gkull
I'm into Sprint car racing. Years ago gear drives were a no no. Now every one has them in 360 ci. class sprinters. They run a light weight 3 gear unit as opposed to your pictured 4 gear. they have no problems running a Mag ignition and the fuel pump & power steering off the back end of billet roller cams.
I have the Crane billet roller setup with my solid roller cam. I just want to here the music of clicking valves. On cruise nights you can hear the gear drives coming down the street.
To Anyone running a CHAIN-LESS gear drive?
